Old 12-14-2009, 04:52 PM   #1
miller6t9
miller6t9's Avatar
radio antenna
I've sprung a leak and it looks to be coming in from the antenna mount. now the antenna that is there probably shouldnt be, and I'm looking at most of the major suppliers to get another. hopefully one that will fit. the LMC book scares me because it describes their antenna as a universal mount. I think thats my problem already. the orange truck and car shop antenna dont look bad. and ecklers looks like theirs is..I dont know I cant tell. anybody been through this?
miller6t9 is offline   Reply With Quote
Old 12-14-2009, 06:25 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: radio antenna
Where is the leak and where is the antenna mounted?
Water will enter into the cowl vent and if your antenna is missing like mine was, you will get moisture in there.
Now if you have a leak coming inside the cab it may be from somewhere else. Some of the culprits are windshiled seal, rusted out or bad seal in drip channels or rust holes under the cowl vent.
68gmsee is offline   Reply With Quote
Old 12-14-2009, 06:30 PM   #3
miller6t9
miller6t9's Avatar
Re: radio antenna
the antenna is mounted on the passenger side fender, in what Im assuming is the factory hole. since the glove box is out, i can tell that the water is seeping through from where the antenna wire is coming. it probably needs sealing as well, but I'm wanting an antenna that will at least be sure and fit correctly, rather than some universal fit that will be questionable.
Old 12-14-2009, 07:37 PM   #4
NYC-10
screamin eagle
NYC-10's Avatar
Re: radio antenna
I just got one from brothers factory repro
SCREAMIN EAGLE
NYC-10 is offline   Reply With Quote
Old 12-14-2009, 07:50 PM   #5
miller6t9
miller6t9's Avatar
Re: radio antenna
it fit well?
Old 12-14-2009, 09:13 PM   #6
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Re: radio antenna
I dont believe the factory mounted antennas on the passenger fender. Im pretty sure they mounted them on the cowl on the passenger side.
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 12-14-2009, 09:31 PM   #7
miller6t9
miller6t9's Avatar
Re: radio antenna
ok...cowl then...I'm just wondering who sells the right antenna
Old 12-14-2009, 09:35 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Re: radio antenna
Antennas are factory mounted on the cowl on these trucks.
Here's two pics. The first is my 68 that came without the radio and the second is the 69 that had the radio option. That is the factory mounting location on the passenger side of the cowl.
Old 12-14-2009, 09:36 PM   #9
wancosc356
wancosc356's Avatar
Re: radio antenna
No experience with them but there are two on this page that claim to be an exact reproduction and just like original.
http://www.classicparts.com/Radios/products/290/2/0
Michael
Old 12-14-2009, 09:42 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Re: radio antenna
Forgot to add that I've read posts from others that have used the exact repro antennas and claim they are a good fit. There are other vendors that are members of this site and are great to work with. I always have trouble finding the place where they are listed, but it's in here somewhere. You can call them or email them also.
Old 12-14-2009, 09:46 PM   #11
wancosc356
wancosc356's Avatar
Re: radio antenna
Here is a list of the site vendors...the guys in gold/yellow.
http://67-72chevytrucks.com/vboard/showgroups.php
Michael
Old 12-14-2009, 10:02 PM   #12
msgross
msgross's Avatar
Re: radio antenna
I would contact a board vendor.. Tim Christian, pickupman, classic heartbeat etc... They are also truck owners and won't do you wrong... some of those shops don't know crap BTW... There is a small rubber grommet that seals that wire, I would remove the cowl and silicone the hole better...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-14-2009, 10:49 PM   #13
cdowns
cdowns's Avatar
Re: radio antenna
i dont believe the factory ever mounted antenni if the truck had the radio option the anntennis were tossed into the front seat and were dealer installed
Old 12-16-2009, 04:23 PM   #14
NYC-10
screamin eagle
NYC-10's Avatar
Re: radio antenna
it fit well?
didn't install yet but looks good
SCREAMIN EAGLE
