Old 12-17-2009, 12:53 PM   #26
Rede
Re: 4WD issue
Thanks Tony.
Will that trick work for both open diff, LSD and spool setups?
Durring the inspection I was told the tranfer case fluid looked pretty clean and it was good for level but I honestly haven't checked it personally since...
Is the 4spd trany supposed to use gear oil or ATF?
Currently there's gear oil, but with no owners manual and being new to a standard, I wasn't sure if this was the recomended type...
Rede is offline   Reply With Quote
Old 12-17-2009, 02:12 PM   #27
Tony@AirRideTech
Junior Member
Re: 4WD issue
It will work with an open diff, spool or anything. Just make sure you mark the tire that spins if it is an open diff. The 4 sp box should have gear oil in it. Only the 208 ( transfer case ) will have ATF.
Tony@AirRideTech is offline   Reply With Quote
Old 12-17-2009, 06:27 PM   #28
oats84
oats84's Avatar
Re: 4WD issue
Im guessing that the gears haven't been checked. For the record there should be numbers stamped on the ring gear. if you have numbers like 41 - 11 you would divide the big number by the small and come up with 3.73s
1989 jimmy "U.A.V"
44/14blt 4.56s locked up
37's
1984 2wd swb
1969 swb 4x4
oats84 is offline   Reply With Quote
