#26 |
motor exploder
Re: My 67 Build Thread
Looks like you have a pretty well equipped shop!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#27 | |
I've found all of the parts that I'd likely use and this actually could be a minimal fab install depending on how far you want to take it. I still need to take some measurments. |
#28 |
I like! Subscribed
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
#29 | |
I have not made much progress in that department. However i know optimally it is good to extend sway bar 3" past frame. Stock Frame is around 39" so 45" would be perfect. I found an off the shelf piece 45" here http://www.kartek.com/Product/Suspension/SwayBars.html They Should be pretty Bullet proof if they serve baja style duty. Additionally Speedway engineering Can Make Just about anything. Although i can make this piece i think my time would be better spent doing other things to get the truck done if there's a part in production already that will fit my needs and is realistically priced. Last edited by rickygee; 12-17-2009 at 10:05 PM. Reason: bad math |
#30 | |
I used to work at Detroit Speed. Below is a shot of one of the hydro formed sumbrames we built for Camaro's. They have splined bars that have arms that are cusom bent. Speedway Engineering offers 3.25 offset arms, or they can custom bend them. My plan was to see if the production run arms would work, if not make a mock up piece out of wood or an aluminum flat stock and have them make one to match. These guys have a lot of sway bar parts as well. http://www.schroedersteering.com ![]() Last edited by Test Pilot; 12-17-2009 at 10:24 PM. |
#31 | |
They are occasional customers of my dad's. The Big thing with extending past the frame is to keep the widest stance possible. the "bar" itself can be any reasonable length and with offset arms it will make up the difference. i am assuming they are using the offset for the extra stance and in order to keep out of the way and aesthetics. Last edited by rickygee; 12-17-2009 at 10:35 PM. |
#32 | |
I was hoping to be able to stick with a 37.5" bar since it seem to be most common from the various stock car manufacturers. This way if a rate change is needed it's not a one off piece. At minimum I'll probably do a lot of auto crossing in my truck, but my real goal is to make is perform respectable on a road course. I've been an instructor for about 5 years now, I've wanted a truck for the track for quite a while now, at the very least I'll ahve a truck that is fun on the back roads. |
#33 | |
#34 | |
http://www.caranddriver.com/features...tenders_page_6 I was also considering something like the Silver State Challenge. Back in the late 90s there was a guy who had a 48 Ford F1 on Lincoln chassis with a 460 and a 4 speed. He was reported to have reached 150 on multiple occasons. |
