Old 04-23-2003, 03:10 PM   #1
1FaastC10
1FaastC10's Avatar
Help!
i've got a bit of a situation on my hands. i was working on the '86 today, and figured out why it wouldnt fire. but the battery that was in it was toast. so i put the battery from my '93 in it so i could take it for a test drive. something isnt quite right with the trans, so i figured just park it, and then mess with it later. i went to take the battery out, and when i pulled on the hood release, nothign happened. either my cable broke or someone decided to be funny and disconnect it. this leave me with 2 undrivable trucks. does anyone know how to open the hood without using a release cable?
1FaastC10 is offline   Reply With Quote
Old 04-23-2003, 03:37 PM   #2
rage'nrat638
rage'nrat638's Avatar
did the handle bust inside the truck?
on the drivers side remove the inner fender(remove tire of course)
the cable from the cab runs right there ,,,may be able to pull there?
or else youwill have to remove the front grill to release
rage'nrat638 is offline   Reply With Quote
Old 04-23-2003, 03:37 PM   #3
BaggedC10
Under construction!
BaggedC10's Avatar
I've had this happen as well. I pushed directly on the hood above the latch with both hands firmly. Did that a few times and it released. I greased the latch assembly and haven't had a problem since.
If that doesn't work, you may be able to open it by reaching up in front of the radiator.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 04-23-2003, 04:08 PM   #4
1FaastC10
1FaastC10's Avatar
im currently trying to get a piece of thick wire hooked around it to release it. i think my cable may have come off, as i can hear it moving around when i push and pull the inside of the handle. but, im not positive thats the case. i cannot confirm this as i am home alone right now. anybody wanna swing by and give me a had, i'd greatly appreciate it.
removing the grille isnt an option, as some of the screws that hold it in are covered by the hood. i hate the way these things are put together, but boy dont they look good?
Old 04-23-2003, 04:17 PM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
You can sometimes reach up through the grille with a long screwdriver and trip the latch. I've done on trucks before.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 04-23-2003, 06:06 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
what swervin said but you can also fabricate some kind of tool outta a piece of rod if you have to i did that once to get the hood open on my old F250
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-23-2003, 06:07 PM   #7
1FaastC10
1FaastC10's Avatar
i got it, finally. i got tired of playing with it and decided to limp it to a bodyshop where i have a couple of friends. we took a piece of 1/4" thick steel and tweaked the front of the hood just enough to get to the bolts that hold the latch to the core support. once we got the bolts out the hood opened right up. it was then that we determined that the cable had come off the latch. i attached teh cable, bolted the latch back to the core support, and closed the hood. opened back up just fine. then took a big ford tool (read:hammer) and pounded the inner part of the hood back in place. looks good as new, works just as well.
