Re: ignition question, confused really
Sounds like some one pulled the dizzy out and put it back in a tooth or two off. Pull all the plugs out of motor put turn the motor to top dead center on #1 cylinder (front driver side cylinder) check were rotor is at if not at #1 pull dizzy and move to #1. you will have to play with oil pump drive to get it to fall back in were you want it but the problem will be fixed
1981 K-5 Blazer 2wd 1985 C-10 Short step 1988 C-10 Suburban
| Bookmarks |
