700R4 Died Violently. DFW Tranny shop?
I installed a 700R4 and loved the fun I had the three days I had with it.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." Last edited by 67_SS396; 04-23-2003 at 01:19 AM. |
Got big-block?
![]() Join Date: Jul 2000
Give Hobarts Performance Trans in Midlothian a call 877-723-9559. They might be able to help you out.
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
If you're on the west side, you might try Phoenix Transmission Products in Weatherford at 817-599-7680 or www.phoenixtrans.com.
I have seen their ads in the truck magazines and have talked to a couple of F-body guys that highly recommended them, although the $800 installed price will be hard to beat, especially with a warranty! Good Luck, Kent
'56 F-100 (w/all GM stuff) Lookin' for another parts chaser! ![]() '05 GMC crew cab |
I always use Transmission Headquaters on East lancaster in Fort Worth.
Not the cheapest but very knowledgeable and quick turnaround. Have Fun
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
I second the Phoenix transmission shop reccomendation. I went through 3 700R4's in my 69 Camaro with a 468 BBC. I went to them and had a 200R built and installed. It gave me ZERO problems and it got beat on pretty hard. They were good guys and reasonably priced.
I third Phoenix Transmissions. Friend of mine is running a 450hp 383 through a 700R4, with a 300 shot. Seems to be just fine. He paid a lot more, for his transmission to withstand that much, but they can build you what you need!!
The guys @ Phoenix said their 700R4 would live behind a 496 w/a Edlebrock RPM top end pkg as long as I didn't bolt up slicks. The quote I got was 16-1700 bucks for everything + upgrades for the tranny cooler.
Scot
Mike
$800 seems kind of low for a 700r rebuild.Especially one for performance.A friend of mine built mine,no charge for labor,and I have over $500 in parts not counting the converter and new trans cooler!
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
Got big-block?
Hey SCOTI, what did Phoenix say about their 200R? The Buick GN guys swear by their built 200R's in those heavy GN's, and the first/second gear RPM drop isn't as severe as with a 700R. I think I'm leaning toward the 200R myself behind my 454. I mean, I might want to bolt on some slicks, you know?
![]() SC
I had the 200R and I beat it pretty hard. I was running a 468 and dyno'ed 612 rwhp. I ran slicks a couple times but ran drag radials all the time. I got it installed by Phoenix transmissions so I could get the warranty. I paid $1900.00 and got a complete deal. Tranny, cooler and shifter. I never had to test the warranty and that's why I would reccomend them. I had my old 700R rebuilt 3 times by 2 different shops and still broke it. If you are making good horsepower I'd check out the 200R.
That's funny . . ... all 4 times I've spoken w/them w/any questions or inquiries, they never mentioned anything about the 200R & I really didn't think to ask.
I have noticed, while looking through my GMHiTechPerf mags, alot of advertisements for 200R's for GN's & late HiPo F-bodies. I never really thought about it but they are similar in weight vs. 67-72's, so I guess the 200R could take the abuse. Only one way to find out. I'll have to make another call & verify some info.
Another advantage of the 200-4R is it is the same overall length as the TH350, so the length of the driveshaft should not be an issue. I think the mounting point is farther aft, so the crossmember would have to be moved.
Kent
Registered Abuser
Does the 200-r4 have overdrive?
Yes the 200 is an overdrive tranny.
Thanks for all the replies and suggestions. I picked this tranny up for next to nothing then sold some parts which replaced what I spent. So as of now, all I'll have into it is a rebuild. I've spoken to many shops in the last couple days and have narrowed it down to two right now. I still have a couple others to call tomorrow, so we will see how it turns out. It's great having resources like this board and others that I frequent, to get suggestions and opinions. Thanks again. |
