Hi folks:
I have a remanufactured Edelbrock 1406. It is replacing a worn out 1405. I did the swap, and now I have to have the pedal to the floor for it to even idle. I have checked for vacuum leaks, and I have the choke hooked up to a switched 12V source. I dont know what the problem could be. I sent an email to Edelbrock today, and hopefully they will have a solution. Let me know any ideas you have. Thanks James |
Could this be a symptom of a float that is not set correctly? Maybe too low?
Gimme some ideas. ![]()
James Strickland AS Computer Information Systems “Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge” ~E.J. Potter |
Registered Abuser
Can actually see that the choke is operating? does the choke plate it'self ever open up?
isnt 1405 a 600 and 1406 a 750? whats the diff. is it choke/no choke? i thought it same same carbs but one without choke assembly.
Seasonal Poster
1405 is manual choke and 1406 is electric I believe...both are 600 i think too
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
Sounds like improper float levels to me.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
