Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 04-22-2003, 11:18 PM   #1
BaggedC10
Under construction!
BaggedC10's Avatar
Thumbs up Hellwig rear anti-sway bar!
Brand-new---Fits 73-87' C10 trucks (Blazer/Jimmy probably as well) and includes instructions. It does need new washers/nuts for the axle U-bolts and new U-bolts. (I test fitted the bar and the nuts on the driver side U-bolt stripped out). It also will need new bolts (Endlinks) for the front assembly because Hellwig supplies crappy hardware. Otherwise, everything is there. I'm asking $65.00 + shipping OBO.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 04-23-2003, 12:45 AM   #2
ocbaud
Garage Queen Material
somebody buy this from him. he is a good busssisissis guy to do work with, and a rear bar helps out a lot. i have this exact same bar.
ocbaud is offline   Reply With Quote
Old 04-23-2003, 05:42 AM   #3
Mike76251
Ocbaud,
I would like to but I have got to have a pic of it installed.
What I need to know is where the bar is located in relation to the center of the rear end cover.
I have a spare tire that just about hits the rear cover now. I think it has maybe 1" clearance.
I know your truck is low and all but look at it this way, several people on here wanted to see your new bar, me included.
Do us all a favor huh? LOLOL
Mike76251 is offline   Reply With Quote
Old 04-23-2003, 07:06 AM   #4
ocbaud
i know i know i know....
my camera batteries are dead and we have no more double aa batteries here. i go to school at 6:50 in the morning and get home from work at 9:30 at night. i've been busy a lot
Old 04-23-2003, 09:45 AM   #5
mckpaul
mckpaul's Avatar
rear swaybar
Hey Eric - yours is the exact same as the one LowC10 is selling... I'm guessing you got the one from swervin a while back, I remember you were wanting it pretty bad. Assuming that's what happened, was wondering about shipping when you got yours, cost etc. I'm guessing it would be close to the same. Also, my truck is not lowered, has the factory sway bar on the front. Any benifit from adding a rear swaybar on a stock setup?
Paul
1984 Chevy C-10
*LWB/305*
mckpaul is offline   Reply With Quote
Old 04-23-2003, 12:58 PM   #6
BaggedC10
Under construction!
BaggedC10's Avatar
The actual bar is like Mike's but Hellwig changed how they mount it. It does not use those large L-brackets outboard of the frame rail or J-bolts. The bolt (Endlink) bolts directly to/through the bottom of the frame rail.
Old 04-23-2003, 02:34 PM   #7
r0lf-
Hotwheels?
r0lf-'s Avatar
Sent you a PM
r0lf- is offline   Reply With Quote
Old 04-23-2003, 03:08 PM   #8
ocbaud
Re: rear swaybar
shipping was about $17 bucks. few cents less. the bar that mike sold me was for a stock height truck(end links = 6") trucks lowered as much as mine have endlinks that are 4.5"
i flipped mine under the axle since my bed is so close to the axle since its lowered. I rear bar should help a lot with a stock height truck, but i dont know from personal experience.
Old 04-23-2003, 03:28 PM   #9
BaggedC10
Under construction!
BaggedC10's Avatar
Also, Hellwig offers two different bars for our trucks---The only difference is the hardware. Being that mine needs new hardware, it doesn't matter what year or height the truck is. The actual bar is the same for our trucks.
BTW, thanks for the help Ocbaud!
Old 04-23-2003, 03:45 PM   #10
Mike76251
No biggie there dude!
Sorry you have such a tight schedule!
I used to do the same thing.
Hang in there 'cause in a hundred years no one will care.
Old 04-23-2003, 04:05 PM   #11
78SilveradoSWB
78SilveradoSWB's Avatar
I can second that, as I bought LowC10's other rear sway bar, which is of the older design with the L brackets and J hooks and can't wait for Eric to post some pictures of his install, but work & school & girl friend comes first. Not necessarily in that order
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 04-23-2003, 06:49 PM   #12
BaggedC10
Under construction!
BaggedC10's Avatar
Thanks but I apolagize for not dusting it off. Did you ever install it?
Old 04-23-2003, 07:27 PM   #13
78SilveradoSWB
Not yet, going to do it with everything else when she is dropped 4/6 later this year, I hope. Got a few more things to get and I'll have everything I am going to need.
Mitch
454 BB, TH400
Old 04-23-2003, 11:03 PM   #14
ocbaud
i'll buy batteries tommorow. prom is saturday so i'll need them anyway
Old 04-24-2003, 12:21 AM   #15
78SilveradoSWB
Just buy some rechargable batteries, then you won't have to wait so long next time unless you forget to charge them....
Mitch
454 BB, TH400
