12-20-2009, 04:40 PM | #1 |
Tie rod adjusting sleeves
Has anyone used the adjusting sleeve that can be purchased at Performance online? I'm upgrading the front end on my '63 c-10 to disc brakes and replacing all the tie rod ends. I'm using parts off of '79 c-10 1 1/4" rotor. I ordered the outer tie rod ends for a '79 and the inner for a '63. The outer tie rod ends screw right in to the sleeve like it should. The inners will not thread? The diameter seems to be correct but just will not thread...
Also, should one end be left and the other right handed threads? http://www.performanceonline.com/sto...cat=787&page=1 Part number HPAS66370 Thanks
My Build "63 Stepside" Major Components 71 350 stock 86' 700R4 My Front Disc Conversion |
12-20-2009, 07:30 PM | #2 |
67-72 parts collector,…
Re: Tie rod adjusting sleeves
I have the POL "conversion" adjusting sleeves on my '69.
You will need to used 63-70 outer tie rods as an inner tie rod. Seems like when they switched to disc brakes in 1971,... they swap which tie rod was left hand thread and which tie rod was right hand thread. I wish POL would tell you this,... because, just like you,... I have a brand new set of inners (that I painted), that I can't use.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-20-2009 at 07:31 PM. |
12-20-2009, 07:34 PM | #3 |
For example,... if your '79 outers are right hand thread,... the 63-70 outers will be left hand thread.
The POL sleeves are threaded with an 11/16" thread for the 71-up tie rods and a 5/8" thread for the 63-70 tie rods.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-20-2009 at 07:34 PM. |
12-21-2009, 06:23 PM | #4 |
Well hell.. What's another trip to the auto store!!!
Thanks for the info and the quick reply...
