Old 12-21-2009, 08:56 PM   #26
78-5.3
78-5.3's Avatar
Re: 4 link !
Originally Posted by 68 TT View Post
The popular one with leaf spring drag cars is the Rancho RS9000X adjustable one. About $90 each.
http://www.calvertracing.com/rancho.php
I plan on getting a set to replace the generic adjustable ones on my car now.
I have heard good things about the Edelbrock Performer IAS shocks but have never used them myself.
i was thinking more of a coil over shock something that would hold the weight with the leafs gone?
78-5.3 is offline   Reply With Quote
Old 12-22-2009, 12:36 PM   #27
68 TT
Still plays with trucks
68 TT's Avatar
Re: 4 link !
I ran these on my 70 Chevelle and was very impressed with them. Not cheap but very nice.
http://qa1.thomasnet.com/item/pro-dr...10&plpver=1001
General info: http://www.qa1.net/qa1_motorsports/
I found this while looking for the QA1 info
http://www.kw-suspension.com/us/kw_p...nPage=coilover
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-09-2010, 10:28 PM   #28
hotrodrookie
hotrodrookie's Avatar
Re: 4 link !
If you like this setup and want the bars on the inside, just swap the front brackets so the origninal left front bracket is on the inside of the right framrail and vise-versa. Just box in the frame rail (after you weld the nuts on the backsides of the holes)and weld the bars inside the fraimrail. If your lower shock mounts are too close then you could weld in new lower mounts if it is a problem.
does anyone now where i can buy a 4 -link kit with the 4 bars rod ends and brackets!!! that i could fit to my truck im not interested in the air ride suspension ! this one from brothers is what im looking for but i want the 4 bars to be on the inside of the rail anyone personal installed one of these kits ?? pics ideas i want the install it on the inside for a massive tire !!!
hotrodrookie is offline   Reply With Quote
