Old 12-21-2009, 02:03 AM   #1
Bigo Serge
Help on replacing the heater core with A/C??
What up fellas,
I'm new here. I got a 72 cheyenne with A/C, and want to know if anyone can guide me in the easiest way to replace my leaking heater core. This isn't my first rodeo with heater cores. I just haven't had to change it on this truck, and I thought I could figure it out as I go on.
So far I have....
1. removed my glove box
2. removed the center air ducks form under the dash with the bolts.
3. removed the bolts that holds the heater core, it just won't budge.
what clips or bolts am I missing?
I have read that the inner fender has to be dropped on the non a/c trucks, is it the same for the a/c trucks? Any pictures will be greatly appreciated. Thanks for everyones information.
Bigo Serge is offline   Reply With Quote
Old 12-21-2009, 07:03 PM   #2
Charles Hettich
Re: Help on replacing the heater core with A/C??
yeah i know on my non ac 72, i just changed the core, and i had to drop the fender and take off the hood hinge. its not that bad of a job. im not sure on the ac pickups tho
Charles Hettich is offline   Reply With Quote
Old 12-21-2009, 08:45 PM   #3
JimKshortstep4x4
Welcome to the 67-72 Chevy Truck Board from West Michigan!
Do you have the heater core housing out? Here is a picture of the housing as looking from the inside, (it is the housing with the relay on it).
The hoses have to be disconnected as well as the housing to firewall fasteners. Once the housing is out there are two sets of clamps that hold the core in place. Usually once you get the clamps unscrewed the core is still difficult to pull out. They fit into the housing tightly and have a caulk on them to seal them in.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-21-2009, 08:53 PM   #4
Bigo Serge
That is exactly where im at. The heater core housing is still attached, but I have removed the bolts that hold it to the firewall from the inside. Are you referring to the fasteners to the thin nuts that are next to the heater core hoses on the (firewall) of the engine compartment?
Pick'em up, lay'em down, Oh Yeahhh
Last edited by Bigo Serge; 12-21-2009 at 09:01 PM. Reason: was not clear in my question
Old 12-21-2009, 08:55 PM   #5
Richard H.
Spanked once
Richard H.'s Avatar
What Charles said about the inner fender is right ,there are one or two at the bottom you can't see or feel.
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 12-21-2009, 09:00 PM   #6
JimKshortstep4x4
Look for some round headed fasteners on the inside of the heater core box. It seems like there are four of them. When you find them remove the stamped steel nuts on the engine side of the firewall.
Jim
Old 12-21-2009, 09:07 PM   #7
Bigo Serge
Great!! I know what you are talking about now. Thanks for your help.
