Old 12-21-2009, 07:53 PM   #1
srea76
srea76's Avatar
brothers rear mount steel tank
Anyone tried these tanks before? They are on sale and I can get it for 250 shipped with everything.
http://www.brotherstrucks.com/prodin...number=GTPDS72
srea76 is offline   Reply With Quote
Old 12-21-2009, 08:54 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: brothers rear mount steel tank
Can't help on the fuel tank, but if you order from Brothers, call first to make sure it's in stock.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-21-2009, 10:07 PM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
That tank is know as the blazer tank. Lots have done the swap including me.......well almost and it seems works pretty good. I'm not quite done, still working on the filler but its not that bad of a project to get it in and hooked up.
Here's a few links to help.
http://67-72chevytrucks.com/vboard/s...ad.php?t=74876
http://67-72chevytrucks.com/vboard/s...ad.php?t=82178
Side marker fill
http://67-72chevytrucks.com/vboard/s...ad.php?t=77104
http://www.classicheartbeat.com/mark...t_gas_door.htm
Good luck! heres mine (poly instead of steel).
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 12-21-2009, 10:14 PM   #4
srea76
srea76's Avatar
i think what I am concerned about is some I have seen cost 400 and this one is only 250. curious why it is so much cheaper.
Old 12-22-2009, 12:00 AM   #5
usmcchevy
usmcchevy's Avatar
I think you are trying to compare a custom made fuel cell(~$400) to this which is just a replacement gas tank for a 67-72 Chevy Blazer that happens to fit the trucks pretty good. Both the fuel cell and the replacement tank are very safe.
EDIT: price break down for mine
Tank: $153 shipped (ebay)
Sending unit and Tank straps: $60 shipped (Classic Parts of America)
S10 Fuel door and filler $5 JY
1 1/4 fuel hose $15 (specialty hose)............If you need 1 1/4 fuel hose start calling around now, I finally found it on about my 25th call.
3/8 fuel hose 25' $10
6' 3/8 brake line to use as fuel line $7 Autozone
by the way Classic parts has that kit for $200 and I think they have 10% off now
http://www.classicparts.com/1969-72-...ctinfo/23-933/
Build thread
LSx Swap FAQ index
Old 12-22-2009, 12:43 AM   #6
energiesource
id rather get a poly tank instead of a steel one.. but thats just me.
btw the rear mount gas tank kit is $199 on LMC
energiesource is offline   Reply With Quote
Old 12-22-2009, 01:00 AM   #7
lsx72
why does nobody use the side frame mount tanks from the later models? will they not work?
lsx72 is offline   Reply With Quote
Old 12-22-2009, 01:01 AM   #8
srea76
srea76's Avatar
My pipes are going to run right next to the tank. Will that be an issue?
Old 12-22-2009, 01:11 AM   #9
usmcchevy
usmcchevy's Avatar
Um.... The ones that mount outside the frame rails thus leading to a major law suit against GM?
Or the ones that mount inside the frame rails- there isn't much room in there with the trailing arm suspension.
My poly tank has a sticker on it saying not to run the exhaust closer than 3".
Build thread
LSx Swap FAQ index
Old 12-22-2009, 09:10 AM   #10
srea76
srea76's Avatar
I will be using a steel tank, but im thinking the pipes as they are now will be within 1" of it.
Old 12-22-2009, 12:07 PM   #11
kopfjaegger
kopfjaegger's Avatar
usmcchevy,
Just wondering about those side tanks, I have two and was planning on using them. Can you elaborate on this lawsuit? If it turns out that they are unsafe, I'll crap can them.
Semper fi Devil Dog!!!
kopfjaegger is offline   Reply With Quote
Old 12-22-2009, 02:02 PM   #12
usmcchevy
usmcchevy's Avatar
Originally Posted by kopfjaegger View Post
usmcchevy,
Basically GM got sued because if the truck took a side impact, the tank was going to rupture and then if there was some source of ignition it would cause it to blow. GM settled for a $1000 coupon good on any new GM vehicle to any owner of the effected vehicles.
You can read more here.
http://www.lieffcabraser.com/gm.htm
Build thread
LSx Swap FAQ index
Old 12-22-2009, 03:28 PM   #13
72 cheyenne pdx
72 cheyenne pdx's Avatar
I have the dealer add-on saddle tanks. I am taking out my tank behind the seat and using these two tanks only. 2 18 gal tanks will be fine. If I get t-boned, then I will worry about a possible explosion then.
72 cheyenne pdx is offline   Reply With Quote
Old 12-22-2009, 05:05 PM   #14
lsx72
yea that is the kind of tank i was talking about. my brother in law has a whole set up he said i could have, but i have never seen anyone use one in our trucks. thats why i was asking if they wouldnt work
Old 12-22-2009, 08:24 PM   #15
rsavage
rsavage's Avatar
Typical mainstream media BS though on these tanks (the regular original GM gas tanks). Either 20/20 or 60 minutes did an expose years ago on these tanks with demonstrations of impacts and big explosions/fires. Only problem with their tests was that they had to mount explosive charges to get the news they wanted. Came out after the fact.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 12-22-2009, 10:24 PM   #16
usmcchevy
usmcchevy's Avatar
I wasn't arguing that they were as unsafe as the news made them seem. Just that for me, if I'm going to go through the trouble of re mounting my tank, I might as well make it as safe as possible. I still own one truck with a side mount tank on it and its staying right where its at.
Build thread
LSx Swap FAQ index
