![]() Join Date: Oct 2007
Anyone Have a 64-66 W/Factory Original V8 and Gauges?
My 64 C10 was originally a 230ci 6cyl with idiot light dash cluster. I have swapped to a 350V8, and purchased a flawless instrument cluster with gauges at a swap meet awhile back. Two questions...
1) Where does the sending unit go for the factory coolant temp gauge? Intake manifold? Passenger side cylinder head? 2) Anybody know where you can get the brass fitting(s) to run the copper capillary tube into the back of the oil pressure gauge? Anybody know what this fitting looks like, or have a photo? Thanks in advance! |
60-66 Nut
Re: Anyone Have a 64-66 W/Factory Original V8 and Gauges?
The temp guage sender goes in the drivers side head. For the oil pressure guage line you'll need a compression fitting that has the pipe thread on one end (I don't remember the thread size) I would think your better local auto parts (NAPA) would have that. They used the copper line up thru at least the mid 70's.
What do the idjit lights work of of?Could you find thier source?
If you are running a V8, the temperature sender is in the front of the intake manifold on the driver side.
The capillary tube assembly, complete with the tube and fittings, is sold at your FLAPS (favorite local auto parts store). It will be in the Mr. Gasket/Accessory section. I just purchase one from O'Reillys a few months ago. |
Thanks for the info guys. The coolant temp idiot light appears to work from a switch in the driver's side head, but I'm not sure the new harness I have will reach that far...will have to check. Unfortunately, the intake I'm using has no bung for a temp sensor, so I will be forced to use one of the cylinder head bungs.
The oil pressure switch for idiot light is at the upper rear of the block, but it will have to be replaced with the copper or brass tubing for the gauge. Last edited by MikeN; 04-28-2009 at 10:28 AM. |
#6 | |
SSN 706
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 12-17-2009 at 06:27 PM. |
![]() Join Date: Nov 2007
MikeN,
To echo Tony's comment. I bought a Sun kit (just the tubing and fittings) at the local Advance Auto for a few dollars and it is very nice. Has all the pieces you need. As for the temp sensor. Most new aftermarket mechanical temp gages seem to use the late model GM sensors that you can get with various electrical connectors and small pipe or metric threaded fitting. Just for reference, the original gages use an older type sensor that is readily available but all I have found is with 3/4" pipe threads that screwed into the intake manifold as mentioned. The graph below shows the difference in temperature vs. resistance reading from the sensors. I have not come up with a way to make the old gage work with a late model sensor that you can easily put in the late model engines. But I'm working on it..... TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 Last edited by TR65; 12-17-2009 at 09:56 PM. Reason: wrong name |
www.lmctruck.com
www.classicparts.com www.truckandcarshop.com all sell the H20 temp sensors and the oil temp sensors. |
#9 | |
SSN 706
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 12-17-2009 at 10:52 PM. |
I ended up using the copper tubing and brass fittings from a kit found at Pep Boys. It may have been a Sun kit, or autometer, I don't remember, but it works great.
The oil sender/sensor for the warning light clusters are electric and the oil pressure gauge requires a capillary tube...there is not sender or sensor. This applies to factory gauges or warning lights...I don't know anything about the aftermarket gauges.
You need a capillary tube from the back of the factory oil pressure gauge to the back of the engine block, near the distributor. Both end are flared, compression male threaded connnectors.
Junior Member
The mechanical gauge is just a pressure gauge. It just measures pressure in the line you run.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! ![]() |
#14 | |
the guage reads the direct pressure. an electric guage needs a sending unit and from there an electric impulse to the guage ron I see that you have asked this before so I thought that I better answer it |
#15 | ||
SSN 706
#16 |
Thanks for clearing that up padresag.
