Old 11-20-2009, 10:15 AM   #1126
78-5.3
78-5.3's Avatar
Re: Glock's new project: "Fred" w/ 5.3L LS swap info
Originally Posted by glock35ipsc View Post
For mine I'll be sticking with either the original TH350, or using a 700R4. I don't want to swap out the original gauges. Either of these two will make the swap simple and inexpensive. Staying with the TH350, I will only need the spacer ($32). If I go with a 700R4, I will still need to spacer, but the trans will be cheap, and I can still keep the original gauges.
hey there i was trying to find what page you swapped the 90-91 speedo and what you did !!!!
thanks
78-5.3 is offline   Reply With Quote
Old 11-20-2009, 11:11 AM   #1127
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
thanks
http://67-72chevytrucks.com/vboard/s...&postcount=581
No pics, but a very basic description of what I did.
Nothing to update on except that I am driving him as often as I can, mostly when the weather allows me to. Like today in fact!!
I'll probably order the Kwik brackets and compressor in early spring and get working on the AC.
My wife and I are talking about another trip to the Bahamas in Feb 2011. I also have some things I need to do to the house.... all new carpet on the main floor and upstairs, lay down hard wood flooring in the dinning/kitchen area, remove the gas fireplace and build an entertainment center in it's place in the wall, and a new TV. So I'll probably just drive him like he is now until we take our trip and get the house stuff done, then start saving for body work and paint.
Otherwise, we are stupid busy at work! Lot's of power plants were trying to save money by not doing any maintenance this summer, and now are having to do a lot of repairs and maintenance that got skipped over. So they have been trying to get parts before the end of the year, before they lose this years budget money. I'm not complaining though!!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-21-2009, 11:06 PM   #1128
Jonboy
Slots go on anything!
Bob, when you got the electric cluster, how much of the wiring did you need to get? Anything else I will need to grab from the donor to make it work? Also, do the gauges get their signal from the PCM?
Jonboy is offline   Reply With Quote
Old 11-22-2009, 01:31 AM   #1129
glock35ipsc
You'll use your existing wiring, you won't need any from the donor. You will just need to re-arrange the wires in your plug to match up to the new cluster. Note where each pin goes on both clusters, and note the wire colors on your harness too. Its really easy, and will make sense once they are side by side.
Bob
Old 11-22-2009, 01:39 AM   #1130
glock35ipsc
Oh, I forgot. All the rest of the gauges work like normal, nothing changes there. The original oil psi sending unit goes in to the bypass block above the oil filter (you will need to drill and tap it for 1/8" NPT). The original temp sender will go into the plug on the rear of the pass head. You can either use an adapter or drill and tap the head for 3/8" NPT.
So, the only thing that will go to the cluster from the PCM will be one wire to the speedo. The speedo uses 3 wires: power, ground, and the PCM signal. It gets its power and ground for the circuit board, so you don't have to do anything extra there.
Bob
Old 11-22-2009, 05:29 PM   #1131
Jonboy
I think whoever swapped the engine in my truck just buried teh original engine harness. None of the gauges work. Hopefully it won't be too bad to sort out. I love a challenge (at least that is what I keep telling myself....)
Old 11-29-2009, 06:58 AM   #1132
solidaxel
solidaxel's Avatar
I was playing with http://autowaretech10.net/nextwheels/tire_fac.htm this morning and came up with:
Fred as he currently rolls:
Fred on 17" Torque Thrust II's, lowered 4":
Fred on 17" Torque Thrust II's, lowered 5":
I'm liking the 4" drop pic (middle one)!
yOU WILL LIKE THE 17" but be carefull with the innerfender clearence with your drop, I have the same set up on my 78 and a big dip at speed and the tire will rub !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-07-2009, 12:53 PM   #1133
Butcherboy
Butcherboy's Avatar
Hey Bob! How things been? Glad to see Fred is running!
Justin
Butcherboy is offline   Reply With Quote
Old 12-09-2009, 12:04 AM   #1134
qu1cks1lver56
qu1cks1lver56's Avatar
this truck looks great with the burban front end. and i REALLY like the 5.3 swap, wish i had the time/money to do one in mine. i bet it gets great gas mileage
qu1cks1lver56 is offline   Reply With Quote
Old 12-12-2009, 01:48 PM   #1135
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Bob you are my HERO. You are the reason I am starting my 6.0L swap. Thanks for all the great info.
What ever the mind of man can conceive......... he can achieve!
My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914
1979 GMC Sierra 6.0 L 4L60E
1995 Mustang GT 347
79gmc5.3 is offline   Reply With Quote
Old 12-12-2009, 03:19 PM   #1136
Butcherboy
Butcherboy's Avatar
Thumbs up Re: Glock's new project: "Fred" w/ 5.3L LS swap info
I agree! Thanks for the build thread! Helped me so much! And thanks for hooking me up with the LS1 intake Brother! The Blazer is coming along great, got my harness almost finished. Decided to do it myself! Wish I went with drive by wire like you did! Fred looks great!
Taker easy, and Have a Merry Christmas!
Justin
Old 12-23-2009, 04:28 PM   #1137
Lemield
Lemield's Avatar
I'm kinda partial to the TTII's myself.
Merry Christmas to you and your family Bob.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 12-23-2009, 04:36 PM   #1138
glock35ipsc
Merry Christmas to you too Larry! When it gets a little warmer and dryer outside, I will bring the door jack back to you and we can go for a ride in the "new" Fred.
Bob
Old 12-29-2009, 06:44 PM   #1139
glock35ipsc
Small update - I stopped by the shop of an old friend today who has a chassis dyno. He looked Fred over and liked it, but got on me for not having the PCM mounted solid. DOH! I actually forgot all about that! So I am going to bump the A/C stuff out 1 month, and get the dyno tune done in February. I'm curious to see what it is putting down at the tires, and how much more we can get out of it.
Justin - I need to go look at your build thread again. I haven't been on that board for quite some time!
Bob
Old 12-29-2009, 08:08 PM   #1140
JohnC
JohnC's Avatar
Sweet man I can't wait to see the numbers that it puts down.
JohnC is offline   Reply With Quote
Old 12-29-2009, 10:58 PM   #1141
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Dyno tune? COOL!!! Let me know when you are going if you would not mind an on looker.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 12-30-2009, 07:21 AM   #1142
menace121978
menace121978's Avatar
sweet! i'm curious to see how much he's putting out. hopefully around 280 or there abouts... with that custom made air cleaner he might be around 300!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 01-02-2010, 12:24 AM   #1143
BulldawgMusclecars
BulldawgMusclecars's Avatar
Wow, great thread! I'm doing a 6.0 swap on a customer's 87 C10 soon, and this has been a great help, esp your info on the dual tanks. BTW do you still have the PN for the high pressure switching valve you used?
Joe Hinds
Bulldawg Musclecars
bulldawgmusclecars@yahoo.com
http://www.bulldawgmusclecars.com
BulldawgMusclecars is offline   Reply With Quote
Old 01-02-2010, 12:35 AM   #1144
menace121978
here ya go...
http://www.jcwhitney.com/MOTOR-DRIVE...DetailTabPanel
"Dennis the Menace"
Old 01-02-2010, 03:28 PM   #1145
glock35ipsc
Thanks Bulldawg, and thanks for posting that Dennis!
I got the remote keyless entry installed today. No pics to speak of since the thing is tucked way deep up under the dash. So here is a pic of the remote so I don"t get yelled at!
Bob
Old 01-02-2010, 03:39 PM   #1146
joe231
joe231's Avatar
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-02-2010, 03:49 PM   #1147
BulldawgMusclecars
Originally Posted by menace121978 View Post
Thanks Menace!
Joe Hinds
Bulldawg Musclecars
Old 01-02-2010, 03:58 PM   #1148
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Hey Bob. great thread. I am starting to source up parts for my ls conversion. Just to be sure, the electric R body speedo is driven from the ls pcm with no drac or other interface?
If so you just gotta love GM's penchant for using the same sandard over and over. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 01-02-2010, 06:12 PM   #1149
glock35ipsc
One wire from the LS PCM straight to the speedo, that's all! Not sure what an R-body is, but it needs to be from a 90-91 Blazer or Suburban.
Bob
Old 01-02-2010, 07:10 PM   #1150
Thealien
Thealien's Avatar
Is the remote start working also?
