12-28-2009, 08:12 PM | #1 |
70 gmc 2 piece drive shaft question
I have the two piece drive shaft and I need to replace the carrier bearing assembly. Does any one know the part number of the replacement bearing assembly. I have tried a few auto stores but they dont have what I need.
Thanks for the help.
1970 GMC truck 1988 Harley 1200 Sportster |
12-28-2009, 08:28 PM | #2 |
Re: 70 gmc 2 piece drive shaft question
12-28-2009, 08:37 PM | #3 |
Gone to greener pastures
Dunno if this will help, or not, I'm lazy; I just take the whole drive line assembly to the drive shaft shop & have them R & R the carrier bearing.
When they're done, I get everything back & it''s all nice & balanced & whatnot. It's just less chance for me to screw up the drive shaft & making things really expensive. Just my li'l .02. Good luck.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
12-28-2009, 08:51 PM | #4 |
I may have to do that but right now its my Daily driver, kinda hard to take the drive shaft along on my Harley. That is if I can fond a shop around here. Im in a very small town in East Texas.
12-28-2009, 09:05 PM | #5 |
GMC Pauls has them listed for $28.95. Both types front rear and side to side. Under suspension parts. I haven't looked lately but I believe ECE may have a beefer one for more coin. Additionally most of the vendors would have these.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
12-28-2009, 09:11 PM | #6 |
in the past some have said there are a few really cheap made ones on the market that don't last but just a few thousand miles and tear up again. Bekieve you maybe better off ordering from one of the board vendors who would likely care about the customer's they want to maintain.
12-28-2009, 09:12 PM | #7 |
OK thanks, I completely forgot about Pauls gmc.
12-28-2009, 09:16 PM | #8 |
i just got the same one for my 71. oreilleys keeps them in stock. before you install it run a weld bead down both sides of the top plate were it was spot welded. i had the first 1 break within 2 weeks. the bearing was made by spicer.
12-28-2009, 09:23 PM | #9 |
NP..While your add it grease them U-joints, don't forget about phasing for staying in balance. I think there is a FAQ on it. Good Luck.
12-28-2009, 09:31 PM | #10 |
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
12-28-2009, 09:56 PM | #11 |
Hey thanks, Looks like Ill be heading to Napa tomorrow.
12-28-2009, 10:05 PM | #12 |
I used one from inland empire driveline this is by far the best bearing you can find.http://www.iedls.com/bearings.html
