Old 12-29-2009, 02:16 AM   #1
Nova70
Nova70's Avatar
Making seat brackets/mounts
I got some seats from an '05 GTO and want to put them in my '70 K10. I have the seat rails from the GTO, the seat is all electric but I'm not sure about how to approach making some brackets to raise the seat. Should I just pick-up some square piping and make a box that will sit between the floor and the seats? How would I make sure the seat is squared in the cab also?
Edit- I also have a bench seat currently and going to be putting my tank under the bed before doing the seats. Thanks for any input.
Nova70 is offline   Reply With Quote
Old 12-29-2009, 06:07 PM   #2
Nova70
Nova70's Avatar
Re: Making seat brackets/mounts
Out of all the seat swaps nobody can help me out?
Old 12-29-2009, 06:11 PM   #3
I would have to see how the seats mounted, but sounds like some square tubing might be the easiest ticket.
Old 12-29-2009, 06:20 PM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I use square tubing and flat stock, the key is to ensure everything is fitted and measure a million times, I am putting electric ram seats in my burb and have them in at the moment, but I am going to replace some square stock with flat stock, to drop the seats about an inch, when your seats are in you want your vision to be about the middle of the windshield.
I removed all the factory dodge mounting and using grade 8 bolts with my steel. I want it to look good so when its done, Ill get it powder coated.
Bottom line is how good are your fab skills and do you have the basic tools to fab?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
