Old 12-30-2009, 12:02 AM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
Cruise control I.D.
Lots of threads lately about cruise for this year and that, what is correct and what isn't etc... I figured i would dig one out and see if the pros could help with this one. My best guess is a 73 4x4 truck with a V-8. Can anyone confirm or deny? Wish it was complete... Thanks, Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-30-2009, 12:41 AM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Cruise control I.D.
Eric, I would say for sure 73-74', but I got one out of a 72' highlander at a junkyard that is very similar to this, but the transducer bracket is different where it bolts to the inner fender, and the vacuum bracket is shape a little different. I know Harold has the exact same setup as I do on one of his nice frame up resto's, and onews6 has pics of the same setup you have in his 72'. I still feel there is strong support that these could be considered correct for late 72' as well since I have seen several of these setups pictured in older threads that either match mine or yours, and of course the correct ones according to the manuals. I still stick with my motto that anything is possible over the years. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 12-30-2009, 12:53 AM   #3
too much stuff
Roadtrip!
I had a feeling you would reply. Thanks for the info. One piece of paper reads march-73. I suppose i should try to find the missing parts for this one. Let me know if you need any better pics of anything. Thanks trevor...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 12-30-2009, 01:02 AM   #4
71blksuper4x4
SWB 4x4 Collector
What is missing from it Eric? You could always get rid of it.
TREVOR
Old 12-30-2009, 01:05 AM   #5
71blksuper4x4
SWB 4x4 Collector
Eric, I will try and get some pics of my setup that I took from that 72' highlander. Like I said, there are some slight variations in the brackets. If you don't mind, I would like to see the installation diagram, I am going to be clueless by the time it is actually going to go into my crew cab a couple of years away. Trevor
TREVOR
Old 12-30-2009, 01:46 AM   #6
71 super
71 super's Avatar
the vacuum bracket I have is similar but fits the fender well and the servo bracket is definitely different from what your kit shows. I will try to get a picture of it and a 68 system that I have as well. Harold
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 12-30-2009, 10:17 AM   #7
chipflyer
chipflyer's Avatar
Hi Eric,
I am with the 73 and up crowd.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 12-30-2009, 10:46 PM   #8
OhOneWS6
OhOneWS6's Avatar
TMS, Any chance of getting a good scan of all the paper work from that kit? It looks very similar to what is on my truck. My cruise has been disabled for a while. Through the years it has fallen apart. At some point I want to repair it. I could see a copy of that paperwork coming in real handy when I do it.
You can see in this pic the diaphragm is toast and there is a stud screwed in to the one vacuum line. I have no idea where that line should go.
OhOneWS6 is offline   Reply With Quote
Old 12-30-2009, 10:52 PM   #9
71 super
71 super's Avatar
Eric, the system ohone has pictured is the same system that I have on my truck. It is also the same system that trevor pulled from the 72 he parted. You notice the difference in the the vacuum pot bracket vs. the unit you have your unit is more than likely for 73 up. Rod would be the member to speak with in regards to correctness as he is a wealth of info on these units, but I have not seen him in forever. Harold
Old 12-30-2009, 11:06 PM   #10
OhOneWS6
OhOneWS6's Avatar
What am I missing about the bracket? It looks the same to me. It's just upside down in the box.
Old 12-30-2009, 11:10 PM   #11
too much stuff
Roadtrip!
I will try to get some better pics tomorrow...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 12-31-2009, 12:15 AM   #12
71blksuper4x4
SWB 4x4 Collector
yeah, I agree that the vacuum bracket that Eric has is the same that ohonews6 has on his truck, but mine is shape different. Mine does not have both 90 degree angles, and the transducer bracket is different. I'll dig up some pics that I have of it that I took of it while it was still in the truck at the junkyard. Trevor
TREVOR
Old 12-31-2009, 12:17 AM   #13
chipflyer
chipflyer's Avatar
I wish Rod would weigh in also. He has answered this question already though.
See this thread
http://67-72chevytrucks.com/vboard/s...d.php?t=136867
Fun discussion, always interesting guys.
Old 12-31-2009, 12:21 AM   #14
71blksuper4x4
SWB 4x4 Collector
Jeff, I did talk to Rod about this awhile back. He did say it was possible as Harold and I have the same setup and then Ohonews6 has a similar setup, but me and Ohonews6 have or got them off of 72's, I think Harold's was on his 71. I have no doubt that the setup you have on your 71 is definitely correct for 71-72, but maybe just maybe this could be a late 72' dealer installed thing? I don't claim it to be, but maybe some dealer's installed these as the new 73's were coming out? That's why I say it could be a late 72' thing as the 73's would be coming out then. Trevor
TREVOR
Old 12-31-2009, 12:26 AM   #15
71blksuper4x4
SWB 4x4 Collector
Notice how many pics of cruise systems on Jeff's link use that Servo bracket setup. It appears to be pretty common, also Bob Moore listed a buddy had a cruise setup on a 71 or 72 that the vacuum was below the horn, which would be quite like the setup I found on the 72. It could be all these parts were replaced over the years, but there are an awful lot of setups similar to the cruise systems in question. Trevor
TREVOR
Old 12-31-2009, 12:45 AM   #16
chipflyer
chipflyer's Avatar
Good point Trevor,
I do think that the dealer installed kits had the early type servo in 71 and 72 and you may be right, in 72 or 73 they switched to the type you and several others found. For whatever reason, they changed the servo and we will probably never really know why.
It's really a moot point, they were all dealer installed in 71, 72 and either style is genuine GM. I will say that since they were not installed at the factory it could be that the one you found was put on that truck in 73, 74, or even 79, there is know way to ever know. Or it could have been put on in 72.
Jeff
Old 12-31-2009, 12:48 AM   #17
71blksuper4x4
SWB 4x4 Collector
Very true, but it would have been pre-75 ish, as the style of cruise control changed. Unless a previous owner installed them, but there is a lot of proof of these things on the truck. This is one subject I enjoy debating and agreeing on with you Jeff. We will never know of course, but finding out answers is what this board was made on. Trevor
TREVOR
Old 12-31-2009, 12:58 AM   #18
chipflyer
chipflyer's Avatar
I agree Trevor,
this is an interesting fun topic to discuss. Beats the heck out of the "How do I hook up my heater hose" question.
We need to find an old parts man from back in the day who remembers this stuff.
Jeff
Old 12-31-2009, 01:48 AM   #19
jaros44sr
jaros44sr's Avatar
Are all these set ups on Quadrajets?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-31-2009, 03:09 AM   #20
71blksuper4x4
SWB 4x4 Collector
yes, I don't think the factory had holley carbs for these trucks during our era. Atleast not to my memory. The setup you just bought from Roger is correct for 71-72 for sure besides the switch, but these setups are up in the air for being correct. Trevor
TREVOR
Old 12-31-2009, 10:35 AM   #21
71 super
71 super's Avatar
Mine was definitely a dealer installed unit, and it was done in 72 not 71 when the truck was new, the original owner did not remember when but he stated that he had it put on after he bought the truck... for what that is worth. By 71 they were definitely dealer add ons as I think 69 or 70 was the last year available as an option. As I have understood it they were having problems with them and people weren't buying them so they discontinued the option and moved it to accessories. This falls into 8 track realm as there are least 2 different 8 tracks that were available through the dealer and both a correct. I would think that then as now as parts availability dictated that was what was passed across the counter, as it all served the same purpose and was hooked up the same. The set up that Eric has I have seen on later g series vans as well, but the diaphram bracket is different. After looking at the bracket in Erics post again, it looks like the bracket that is on my unit. The unit that Roger has listed for sale I believe is the generally accepted unit for our trucks, with the type Trevor, OHone and I have were prob. units added later on -as in late 72. Anything and everything can and does happen at a dealership, when I was working in one while in college a salesman sold a z71 but ordered a regular 4x4, the new owner came in and pitched a fit (rightfully so) and three days later he had a z71- built from the parts room and order desk. Same truck with added skid plates, stickers etc. that came with the z71 designation. If it happens now, it happened then. Forty years from now someone is going to flip out trying to figure out the deal on that truck (if it has not rusted to the ground or crushed as a clunker).
Old 12-31-2009, 11:21 AM   #22
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
this is interesting stuff here. I am wanting to put cruise on my truck some day. would it work w/ an edelbrock carb?
LOW DOUGH is offline   Reply With Quote
Old 12-31-2009, 11:32 AM   #23
OhOneWS6
OhOneWS6's Avatar
I don't know when mine was installed but what I do know is that cruise was on it when my dad bought the truck. It was in the mid 80's and it had 107K on the clock. At that time the truck looked show room new and the cruise certainly looked original to the truck. I remember commenting on it when he brought the truck home. My guess would be, as some have already stated, the truck was purchased new in late 72 early 73 and the cruise was installed at that time by the dealer.
Old 12-31-2009, 11:34 AM   #24
OhOneWS6
OhOneWS6's Avatar
It should be fairly simple to add with the Edelbrock. There are a number of universal aftermarket cruise options available today. Especially if you do not want a period correct cruise.
Old 12-31-2009, 12:37 PM   #25
jaros44sr
jaros44sr's Avatar
I was just looking at one of my Quads, and one of the newer ones has a stud bolt to accept the cable for the cruise. So, you should be able to drill a hole in the Edelbrock linkage to accept this bolt/stud. My problem seems to be the bracket where all three cables mount to the carb or engine. Haven't quite been able to idenify or find out where to get one, yet
Great info. guys
Sorry Guys for the thread jack, just trying to answer a question
SAFETY FIRST
AS usual, off topic
Jim
