#51 |
Re: Help with new vent window rubber
Benntn, is there any particular reason why you went with Brothers as opposed to LMC's 2 piece seals? Also, do they look the same as the originals, because the 1 piece ones clearly do not fit, eventhough I installed them anyway!
I'm guessing that 2 piece units must be replaced with 2 piece units! |
#52 |
Still plays with trucks
On my 78 the PO cut the vent window seal to route a CB radio antenna cable through. After I removed the CB I now have a hole in my vent window seal.
I have another driver side door from an 87. Can I get the 87's vent window assembly out and into the 78 door without having to remove the seals from it?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars Last edited by 68 TT; 12-28-2009 at 04:52 PM. |
#53 |
For what its worth, back in 03 I put new seals in my 86. First I bought some from LMC. (one piece) and after fighting with them for a while I called the Chevy dealer and got new OEM ones. The GM ones were not any better and I believe I ended up using the LMC ones. It was a pain but well worth it.
#54 |
![]() Join Date: Feb 2009
Yes.
-Don- '66 ![]() '77 ![]() '80 ![]() '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf ![]() |
#55 | |
#56 | |
#57 |
Project Optimus Prime
man this sounds like alot of trouble. u guys are makin me scared 2 tackle this job
84 SWB work in progress ![]() ![]() 89 burb 1500 (parts pig) LOL ![]() 08 ford focus (I know, I know) Wifes car ![]() "I said it b4 and i'll say it agian wiring is my worst enemy":devil: ![]() |
#58 |
Makes those one-piece windows sound even better doesn't it.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#59 |
LOL u kno i was thinkin tha same thing!!!
#60 |
haha I went through this dilema and I decided to call up one piece products because i hate wind noise and they look sweet.
#61 |
I'm suscribing, this is my next project I have tackle, gonna try to take pics along the way. Damn this is going to be fun!!!
GROUND ZERO IS R LIMIT ![]() |
#62 |
Man... I have two of those LMC one-piece seals waiting in the garage for the 81 C2500. Along with a TH400 to rebuild that will be a first for me..... I think I'll start with the TH400
![]() Jim P
1981 Sierra C2500 LB Fleetside, 350M, Th400, QJ, 14bolt 10.5" rear. |
#63 |
No, I'd say spelling and or basic grammar are your major foes.
![]() The worst part of this job is getting the L shaped gasket fully seated in the corner. Liquid soap helps, but only so much. I use a hex head bolt in a vise for a buck when doing the gasket rivets. Order an extra set. For the price, it is nice to have spares on hand in case things go south, esp. the pivots.
#64 |
