Old 12-23-2009, 07:39 PM   #26
GRIMSS
GRIMSS's Avatar
Re: Air Ride Install - '69 Chevrolet SWB Stepside
Looking good Doug. I need to come and check it out sometime.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 12-23-2009, 08:20 PM   #27
Sinister
Between Trucks...
Sinister's Avatar
Lookin good Doug. Subscribed.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-23-2009, 10:06 PM   #28
tcb-1
Nothing to see here.....
tcb-1's Avatar
was visited tonight by a box full of SMC valves from suicidedoors. first off, let me say that ***************** is a great place to do business with. I ordered these valves Monday, and here today and packaged well...... and I stole them @ $22 a piece. brand new, still in the factory bubble wrap. so now I have......
I removed the front springs tonight. here's a tip. if PB Blaster doesn't work to get the taper fit free, try a propane torch. only heat the spindle body, not the ball joint studs. the heat will expand the female taper fit. works like a charm eerytime I remove ball joints.
Chris, I plan on checking the front cups (drop ins) for fit and finish. I am also completely cleaning the front suspension as well as I can until I can put it on a rack. (hint hint scottrod?!)
got to thinking tonight about a "backup" in case the compressor failed. I may put a tee on at each bag and run a Schrader. bad luck tends to follow me, so anything to increase my odds in the other direction, I should explore.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 12-23-2009, 10:46 PM   #29
*Dylan
Mean Buzzin' Half Dozen
*Dylan's Avatar
Looking great, I can't wait to see how this progresses.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale)
1967 C10 SWB
Dylan
*Dylan is offline   Reply With Quote
Old 12-23-2009, 10:52 PM   #30
tcb-1
tcb-1's Avatar
Nate,
I used Rustoleum Industrial OIL based enamel in flat black in a can. it goes on smooth, self levels, and after dry, is fairly tough, especially when brushed on.
I was going to use POR15, but that stuff does NOT come off..... and eventually, I want the frame completely blasted and powdercoated. but for now, this is a viable choice that will come off under normal media blasting. I highly recommend the Rustoleum for normal underbody protection!!
Doug
Old 12-24-2009, 05:33 PM   #31
Grandpa's CST
Grandpa's CST's Avatar
Sounds like the balljoint delema is solved, another way to do it is loosen the castle nut half of the way on the balljoint and while the joint is under spring load take two 3 lb hammers, one is held tight against one side of the spindle at the joint mounting and then the other hammer stikes the opposite side of the spindle temporarily oblonging the hole and releasing the two, make sure from here the spring is unloaded again before the nut is removed, usually works first or second hammer blow.
Like the project, subscribing.
..........._____|__\___
..........|_(O)_____(O)]
Grandpa's CST is offline   Reply With Quote
Old 12-24-2009, 09:34 PM   #32
soala70
soala70's Avatar
got to hook on
bogey5
soala70 is offline   Reply With Quote
Old 12-24-2009, 10:33 PM   #33
firedog
firedog's Avatar
the rear install is pretty much bolt on. The front depending on how you do it is a little more demanding. Good Luck and you will want to go lower it will be just a matter of time. As far as a back up to the compressor put the schrader valve on the tank.
I sent you a pm also
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 12-25-2009, 04:20 PM   #34
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Okay Doug... what pieces did you unwrap this morning?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-25-2009, 06:13 PM   #35
tcb-1
tcb-1's Avatar
how did you guess, Nato??!
got rear shock relocators (ECE) and front bag bracket/cups.
Doug
Old 12-25-2009, 06:21 PM   #36
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Awesome!
-Nate
Old 12-26-2009, 01:19 PM   #37
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Gonna be sweet man
I have some dodge 17" wheels like yours, but never wanted to re-drill my axles & stuff for them to fit
As for the bags, I would buy the Slams... I have both & the Slams look much better made
As for the back up, I put a schrader on my tank as well
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 12-26-2009, 01:58 PM   #38
tcb-1
tcb-1's Avatar
spray bomber,
if you have a 67-70 truck you want to go 17" steelies on, these will work straight outta the box. they are Toyota FJ Cruiser rims, 17" x 7.5" wide on a 6 x 5.5" bc. I'm running a .75 spacer on them now, but once the truck is lower, I may remove them to tuck in better.
I've always liked your builds! thanks for coming by my build. my truck will still look like a 4x4 compared to some of your rigs!!! !!
Doug
Old 12-27-2009, 12:33 AM   #39
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Doug awesome dude...You know you have my favorite truck of all time...Now you are going to make me get a 2nd job and put sweet pea on air huh? awesome dude.......Cannot not wait to see it.........
bad6772 is offline   Reply With Quote
Old 12-28-2009, 02:01 PM   #40
invicta455
Doug looking gooood
invicta455 is offline   Reply With Quote
Old 12-28-2009, 09:43 PM   #41
bigguy69
dazed and confused
bigguy69's Avatar
looking good! subscribed!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 12-28-2009, 11:43 PM   #42
tcb-1
tcb-1's Avatar
starting on the bolt on upper bag plates tonight. made my own drill bit to get to one of the holes.... call me McGyver!
took my suicidedoors drop in bag cups in this afternoon to get a shave. I estimated 5/8" off the total height would be good.
I'll get pics soon of my progress.
and.... thanks guys for the kind words. I hope I won't disappoint!
Doug
Old 12-29-2009, 01:11 AM   #43
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good Doug!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-30-2009, 10:33 PM   #44
tcb-1
tcb-1's Avatar
got a little done over the past couple of nights. I also ordered my bags. with a lot of thought and with suicidedoors recommendations, I went with Airlift Dominator D2600's. can't wait 'til they show up on the doorstep! thanks again suicidedoors!
first, I took my drop in lower bag cups to my fabricator and had him cut them down approximately 5/8". they seem to sit perfect now. 5/8" doesn't sound like a lot, but it actually is when your trying to get as close to the floor as you can. here's the look of the cup in the pocket:
you know, specialized tools are expensive, but my God, they are so worth it. I even cut down a drill bit, and made my own short length bit. when you have to get something done, nothing should stand in the way......
nothing's more beautiful than a cab full of new parts.....
and for the grand unveiling..... in this pic, I raised the entire assembly up to when my tire was touching the inner fender. I measured and I still have about a inch to play with if I decide to ditch the inner fenders. but for now, this is where I'll dial the front end to.....
and lastly, this is where I would be without inner fenders.. and without a tire:
the first place I head to after we get back on the road is my muffler shop!! may have to modify the crossmember, buy a CPP unit, or drop out right under the cab. oh well, that decision for another day.
and before I wrap up this installment, I want to thank LOLIFE99 for giving me the kick in the pants to go on air. Keith is a great guy and knows his stuff. I owe you.......
hope everyone has a safe and an enjoyable New Year!!!
Doug
Old 12-30-2009, 11:47 PM   #45
LEEVON
Moderator
LEEVON's Avatar
Looking good! Are you talking about the trailing arm or transmission crossmember?
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-30-2009, 11:49 PM   #46
tcb-1
tcb-1's Avatar
Leevon, should have clarified... the trailing arm cross member.
Doug
Old 12-31-2009, 08:36 AM   #47
lolife99
67-72 parts collector,…
lolife99's Avatar
Great Progress Doug! (Thanks for the kind words also)
If you decide to get a trailing arm crossmember,... DEFINITELY get the Porterbuilt unit.
http://porterbuiltstreetrods.com/site/?p=178
These are by far, the nicest ones out there. (I just happen to own one now)
Plus, they have the multiple mounting point to help dial in the pinion angle.
And,... you might as well get a set of Nate's new tubular trailing arms,... and,...
Keep up the good work!
Old 12-31-2009, 09:34 AM   #48
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice work Doug!
I was in your hometown for a little while yesterday. Needless to say they didn't receive any snow...
-Nate
Old 12-31-2009, 08:05 PM   #49
powell72
powell72's Avatar
Looks like you're making some good progress.
I gotta ask, is your truck always that clean?
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 12-31-2009, 11:59 PM   #50
tcb-1
tcb-1's Avatar
As a matter of fact Chris, I'm on medication so I'm not so clean and organized !!
Doug
