Junior Member
![]() Join Date: Oct 2005
Big block cooling fan
What is the best setup for a big block cooling fan. I have a '96 454 with '96 brackets, water pump,etc. Using '72 big block motor mounts. I dont have much room for anything between water pump and radiator. My electric fan set up will be very close to rubbing. I have the electric fan shroud from GMC PAULS.
1970 C-10 Fleet Side Gen IV 6.0 with 4L80E |
Re: Big block cooling fan
We have a set of electric fans off of a 96 z28 that we plan to use with the same bbc setup. I think we will have just enough room for them to fit without problems. I have the same setup on my sb406 and they have done an amazing job keeping it cool even on triple digit days.
Hollister Road Co.
You may want to look at the Mark VIII or Taurus fans
If you have 6.5 inches fron fan pulley to radiator a Mark VIII will fit. |
Some of the Virgo fans are slim too less than 2" thickness.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
"THE GREEN GOBLIN"
I am running z28/camaro dual Fans on my 454 it is alittle tight with my pullies but they clear with no problems I don't remember what year they are from.. This is a old picture as you can tell my motor is dirty and I wasn't Using '72 big block motor mounts. Since this photo I have changed to the Stock '72 big block motor mounts, and there is about the same clearence I will try to find a picture somewhere I know I have one of what it looks like now if not I will take a good picture of it today.
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
"THE GREEN GOBLIN"
Heres another pic. I did have to slide the fans over a bit to clear the pullies & electric water pump..
#7 | |
