Old 01-02-2010, 05:17 PM   #1
rddaves54
rddaves54's Avatar
Question testing horn relay?
Can I test a horn relay 1972 chevy to see if it is bad? I hotwired the horns and they work and the horn button worked before so the only thing left is the relay. But I wanted to test before I bought one.
Chief mechanic for my, 54 Belair, 64 Corvair, 72 C/10Fleetside and 2002Tahoe.
John 14:6 Jesus said, "I am the way, the truth, and the life. No one comes to the Father except through Me.
My Book "Why Cancer is Not Bad Luck" by WestBow press
rddaves54 is offline   Reply With Quote
Old 01-02-2010, 06:44 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: testing horn relay?
I don't know the exact pin configuration, but it should be easy enough. It normally has 12v on it, and the horn button sends ground to activate the relay. If it operates (you can hear it click), either check for continuity across the output pins with a VOM, or apply 12v on one pin and check for 12v on the other.
There's a chance the 12v to operate the relay is the same 12v that is sent to the horn.... in other words, there may be a single 12v connection. If that's the case, just ground the input and check for 12v on the output pin.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
