#51 |
Re: Tailgate Bands Pics/options/diy
if someone drew out the dimensions for me i could machine one up in no time.
i made those billet chevy bowties a while back
"I'll keep my guns, money, and freedom. You can keep the "change" |
#52 |
Still plays with trucks
If we can get the dimensions from somebody I will put it into AutoCAD and create a dimensioned drawing that I will share with you and anyone else who wants it.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
#53 |
3/4 Ton Rodder
68 TT, if you make a billet one, I would take one, provided the price isn't too high. If I can get one, I'd take it without a brushed finish, I want to polish mine out to a shine.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. |
#54 |
I would say a nice one would be @least a grand.
#55 |
Dually Pride
hmmm...milling time would be forever so it would cost alot....we have a plasmaCAM at school (CNC plasma cutter) that could cut the CHEVROLET out then do the outside shape, so you see the body color below (or add an insert. if you found someone with one of those to produce them, they can pop them out lickety-split. but it would be kinda crude.
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually ![]() '94 Ford Ranger |
#56 |
Addicted to Rust
![]() Join Date: Dec 2009
Get me a file I got a buddy with a CNC that sits idle. I will get a qoute. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
#57 |
About $12 for a piece of 1/4" x 3" x 48" 6061-T6 aluminum flat bar, 1/2-hour on a mill to cut the perimeter profile, edged bead detail and the lettering.
The lettering square edges would be rounded in some areas if you milled them out but you could minimize this to 1/16" radius with a second pass with a small cutter to just hit the rounded edges. If plasma or water jet cut to remove the lettering areas completely and to get the basic shape cut out it would be about the same cost and the lettering would be crisp and square at all the edges. You could then water jet or plasma cut out the individual letters and press fit them to the band. A proper .002" press fit with the band heated up and the letters frozen would never come apart. With milled out lettering probably $200 and with water jet cut lettering probably $350 to $400 unless a small production run was done then the price would drop quite a bit. You could also put a cover piece on the back side of the water jet cut band so nothing of the tail gate was visible through it pretty easily.
#58 | |
I will take some measurements on my truck this weekend and put together a cad file you can use to run by your friend. Once we get original small band dimensions I will refine the shape to match but this won't change the milling costs. I will overlay some of the pics of the small band to get the details of the lettering correct too. More modern custom lettering and locations are easily possible too. I was thinking that the right hand side offset lettering would look better on these smaller bands.
#59 |
Another totally different route-
I had a hot rod man take a look at this band (mine is all dented and effed up) and he said we should remove it, sand and paint whatever's under it, and then have an airbrush man come in and paint the band back on in 3-D airbrush style. I know, I know, it sounds pretty "Tokyo Drift" style, but I've seen this duder's work, and it's clean. Pending costs and other options, you guys may see an example of that work real soon... |
#61 | |
#62 |
I've seen some of the airbrush trim stuff and didn't care much for it. Don't get me wrong I appreciate all the work, and skill that went into it, but is just didn't look right.
#63 | |
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " |
#64 |
That looks good man! I like it!
#65 |
At the body shop.
Thank you. Now i have get the nerve to cut the dash out. And fab a 62 or 65 dash in it
#66 |
There is a lot of good information here. Thanks for resurrecting the thread. It started me thinking. I went out and took pictures of tailgate bands I had stashed away. Maybe it will help someone see about them. In the picture from the top down the tailgate bands are: 1: 1981 GMC, 2: 1974 Chevy, 3: 1980 Blazer, 4: 1979 Chevy truck, 5: 1976 Chev Custom Deluxe truck, 6: 1974 Cheyenne truck. I believe these are correct, but perhaps not. I usually wrote the information on the back when I removed these. The last picture is the tailgate on my truck, (NO tailgate band, LOL)
James |
#68 |
That's off a 88-98 truck.
#69 | |
3/4 Ton Rodder
#70 |
Here are pictures of the back. The cut out ends of the spacer piece on the back look weird. I don't know if someone cut these to fit or if they are original. JohnC is right about the bumper.
James Last edited by jlmerie; 01-02-2010 at 08:29 PM. |
#71 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
nice console stash. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach):2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#72 |
Location: Where I come from, it's cornbread and chicken...
+1...someone must be putting some stuff away to sell for retirement...lol
#73 | |
Gettin It One Pice At A Time
RIP ELJAY ![]() Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
#74 |
I have one...
#75 |
misshape grape
wow, i really like the way the blazer band looks!!
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did.. |
| Bookmarks |
