Has anyone ever attempted to put a 2wd cab on a 4x4 frame. I realize that a 4x4 cab has a large hump for the transfer case but if you were to do a body lift on a 2wd cab would it fit.And if it were to fit how much body lift would be required. The only thing I would think I would have to do is punch a hole for the transfercase shifter. Am I correct? What is the purpose of the transfercase cuttout (maintenance,adjustments)?
Re: 85-2wd cab-80-4x4 frame
Buddy has a 2wd body on his 4wd. Think he used a 3" body lift. The box is on a frame for a dumpbox, but never hooked up. That is the only difference between the two anyways is the tranny hump. If the 2wd is a stick, it will have the taller hump.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS Last edited by b454rat; 01-04-2010 at 10:22 AM. |
Robert Olson Transport
![]() Join Date: Oct 2002
you can get the unboltable hump outta the 4wd cab and place that in the 2wd cab so you dont hae to do the body lift i believe search that its been done before
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
It'd be alot cooler if you did
As Bob mentioned, you can cut the floor and bolt the hump into the two wheel drive cab with very little modification.
