landarts
![]() Join Date: May 2005
Side mount Gas tank door ????
I have side mount gas tank doors on my 72 LB, they are old and rusted. Is there a better way to have access to the tanks or different more custom looking doors that anyone has used?
member #16
![]() Join Date: Dec 1999
Re: Side mount Gas tank door ????
Heres some new shiny ones.
http://www.pakindustries.com/tank_door_info.html
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Here is mine I cut out of a 90's truck
69 Chevy 4x4 383 Power ![]() |
![]() Join Date: Jul 2009
Here's the one on my '72 GMC. The PO had it installed and said it was from a Pontiac Firebird. I don't know what year.
Mike Mileski Tucson, AZ |
I like that Mike. That is exactly what I was thinking about doing on my 71. I'm more after convenience than smooth and slick or tricky as I use the truck for everything. I have the burb tank and need to get it done as I bought a camper shell for it and need to take out the big tank in the bed.
landarts
I like the looks of how that was done. It looks like it belongs there! I think that is the route I will go with mine . Now I need to find 2 of the same donor doors since I have a tank on both sides. Thanks
While on the subject, does anyone make replacement side tanks for the 67-72's? This seems to be almost a taboo subject. Were the tanks no good? Unsafe?
Never Ending Projects
I thought I saw a post that gave a link to a company still mading side tanks for both sides. IIRC, they were not cheap, like $400-$500 each.
If you really want (or need) one, I have a driver side tank I removed from mine I would let go fairly cheap, if you want to drive down to San Diego to pick it up.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
landarts
I already have the tanks installed on the truck ----see post #1. I want to replace the tank doors with something different than what I already have.
Sorry, I was replying to 69GMCLonghorn.
![]() For me, I am going to use the stock area from a '67-'72 Suburban so it looks like it was factory. On my last '68, I grafted in a door from a Buick. Went to the junkyard and looked around until I found something that looks good, cut it out, took it home and welded it in. This was pre digital camera days so no pics.
