Old 04-25-2003, 10:37 PM   #1
Dads72
Lowering Blocks Install ?
Could someone with patience and experience talk me through this, please?
I'm getting lowering blocks, and have no experience with rear suspensions.
What do I support/jack up/etc. to install them without killing myself?
Bet it's pretty simple, but I admit my ignorance.
Dads72 is offline   Reply With Quote
Old 04-25-2003, 10:38 PM   #2
Dads72
Should have mentioned that it's on a 72 LWB with coils and helper springs.
Old 04-25-2003, 10:39 PM   #3
Randy70C-10
Randy70C-10's Avatar
The easiest way I can think of is to jack up the frame of the truck itself, and support it with jackstands. Then you can lower the trailing arms.
Randy70C-10 is offline   Reply With Quote
Old 04-25-2003, 10:40 PM   #4
Randy70C-10
Scratch that, you don't need to jack up the frame, just support it.
Old 04-25-2003, 10:41 PM   #5
Dads72
Thanks again, Randy.
Do the rear wheels stay on the ground, and do I put a jack under the pumpkin?
Old 04-25-2003, 11:45 PM   #6
orange72
orange72's Avatar
yea i would prabably jack the truck up until all the spring pressure is off the trailing arms then support the frame with some jack stands..then you can just unbolt the u-bolts and lift the axle up with the jack stands and slip the lowering blocks in between. then bolt it back up and sit her down on the ground.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 04-26-2003, 12:39 AM   #7
Low69CST
I would put the jack stands under the trailing arms and use the jack to push up the rear end after you get the nuts off the ubolts. I've found that they are usually rusted together ubelieveable well. It usually takes a big sledge hammer to get them apart.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 04-26-2003, 05:55 AM   #8
Seke69
Space Cadet
Seke69's Avatar
are lowering blocks different for coils? or are they the same as the ones for leaf springs?
Seke69 is offline   Reply With Quote
Old 04-26-2003, 06:45 AM   #9
Nova_Cobra64
Nova_Cobra64's Avatar
I was looking at my 69 a while back and noticed the rear end is already underneath the trailing arm and figured that they must make block kits with longer U bolts. Mow much does a kit go for, and does it affect handling in negative ways?
My dad seems strongly against lowering, but I figure I need 2" all the way around to finish the truck off.
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 04-26-2003, 02:32 PM   #10
pissonNOS
senior member
pissonNOS's Avatar
my dads the same nova_cobra64 damn old schoolers he didnt even like it when i put a Rockford deck in haha
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 04-26-2003, 04:56 PM   #11
Randy70C-10
I was tired last night. Go with what orange72 said and you'll be fine.
