Senoir Member
65 Chevy engine swap
Hi Guys. How much trouble is it to install a 350 into a 65 Chevy truck that originally had a inline 6? Are the engine frame mounts different? How about auto trans bolt up? Any help would be great.
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
Depends on if you are transplanting the trans with the motor.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
Senoir Member
Had not planned on swapping the auto trans yet, but will if I need to. What's the difference?
Senoir Member
ttt
AND HOLDING ON TO THE C10
the frame mounts are different because the v8 has a wider stance mounted pm me if you want more info on the swap i have done this alot of times i used to do this for a living
66 swb/ss chevy c10 ![]() 62 swb/fs chevy c10 :p SOLD 84 swb/fs chevy c10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() 91 sdime 383/th350 ![]() |
You might consider changing the radiator for a larger capacity.
Senoir Member
truckman32, sent you a PM. Thanks.
