ok so i got a '66 c20 3/4 ton that i'm swappin '84 c20 discs to. got the spindles and rotors on but my problem is the tie rod ends for the 66 don't work (larger diameter) on the 84 spindles, my question to you good fellows is, should i change the whole center link with tie rods from the 84, which i don't have anymore
![]() ![]() ![]() ps cant drive my darn truck till this is figgered out!! sucks!! |
Re: '66 c20 to disc and keepin the 8 lug, help!
you will need the '73 up c20 center link and tie rods c10 may work not sure
Sleeving tapers is NOT safe
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
#3 | |
60-66 Nut
I agree with 62gmc910
I would just find the steering linkage from a '73-'87 C20. I wouldn't think it would be too difficult to find.
