Old 01-05-2010, 05:08 PM   #1
vegaschevy
installing a rearview mirror
I have ried to install my rear view mirror three times now and NOTHING seems ot work. The last time I used some adhesive from the auto parts store designed for rear view mirrors and it was holding well i thought until I washed my window and touched it and it fell right off...
i need something good and strong!!! suggestions??
vegaschevy is offline   Reply With Quote
Old 01-05-2010, 05:11 PM   #2
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Re: installing a rearview mirror
Super glue?
It's been a long time since I put one on and have no idea what I used to use. Im sure someone will chime in.
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 01-05-2010, 05:25 PM   #3
fishingjred73
fishingjred73's Avatar
I've always used the rear view mirror adhesive with no problem. Just gotta make sure everything is clean.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 01-05-2010, 05:34 PM   #4
vegaschevy
brake cleaner, dry, everything has been perfectly clean! I was thinking about going by a window installation place and trying there.
Old 01-05-2010, 05:49 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Maybe the brake cleaner is reacting with the glue. I just use glass cleaner and the auto parts place mirror glue.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 01-05-2010, 06:11 PM   #6
71swb4x4
71swb4x4's Avatar
I used an alcohol wipe to clean. Make sure you are cleaning both the glass and the metal or plastic insert that you are gluing to the windshield.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-05-2010, 06:34 PM   #7
vegaschevy
both cleaned very well and dried, im not sure what the problem is grrr
Old 01-05-2010, 06:38 PM   #8
72 cheyenne pdx
72 cheyenne pdx's Avatar
I had the same thing happen, and what I did was scuff up the mirror and the windshield where I was installing it. It is still holding, knock on wood.
72 cheyenne pdx is offline   Reply With Quote
Old 01-05-2010, 06:51 PM   #9
coopdeville
duct tape!
myspace.com/southtacomaalleyrally
coopdeville is offline   Reply With Quote
Old 01-05-2010, 08:03 PM   #10
ERASER5
ERASER5's Avatar
Did your glue package have primer with it? I only use Loctite brand with primer.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-05-2010, 08:07 PM   #11
tremman78
tremman78's Avatar
was the glue loctite? if so, they changed something in their formula and now it sucks!
tremman78 is offline   Reply With Quote
Old 01-05-2010, 08:14 PM   #12
tommys69/454
1969 short box
tommys69/454's Avatar
did you let it dry long enough before hanging the mirror? I just scrape, primer, glue and hold in place for a minute. seems to me that it would be warm enough in Vegas. LOL
tommy morehouse
tommys69/454 is offline   Reply With Quote
Old 01-05-2010, 11:03 PM   #13
hayhauler71
hayhauler71's Avatar
We use loctite brand in our shop with great results just let it dry 24 hours before installing the mirror.
hayhauler71 is offline   Reply With Quote
Old 01-05-2010, 11:20 PM   #14
snowblind
snowblind's Avatar
Did mine a few months back with the loctite glue. Cleaned with alcohol first. Used the special hardner. Worked perfectly.
Matt
'72 Jimmy Build
snowblind is offline   Reply With Quote
Old 01-06-2010, 03:50 PM   #15
tqlspec
tqlspec's Avatar
if you use too much of the glue it will not hold. One drop is all it takes.
tqlspec is offline   Reply With Quote
Old 01-06-2010, 04:06 PM   #16
piecesparts
Parts and more parts
piecesparts's Avatar
When you clean the windshield, get a razor blade and use it like an ice scraper to shave any finish off the glass. The use of the alcohol is the right cleaner, but the blade takes off any clear finish that may not let the glue adhere to the glass.
Frank
