Old 03-23-2003, 06:49 PM   #26
crazy longhorn
Fabricate till you "puke"
I dont call myself a pro, but am a hobby welder/fab "geek". I agree, if the weld has good pentration, it shouldnt be a problem grinding it smooth. after you plate or box the inside, you have all the strenght you need....crazyL
crazy longhorn is offline   Reply With Quote
Old 03-23-2003, 11:18 PM   #27
79GMC454C35
Lightbulb frame welding
why dont you "V" the inside of the frame. Weld from the inside out. Grind the out side penetration smooth. Then "Box" the area 8" or so on both sides of the splice. This way the box hides the weld, & makes the frame stronger. It will also be less work because you will have less grinding to do. And, you will not have the splice in the back of your head when you jump off a curb to chase down a hooker.
79GMC454C35 is offline   Reply With Quote
Old 03-24-2003, 04:04 AM   #28
Notford
If the weld penetration is correct(good weld), you can prep the weld flush. Do not butt the frame sections, fab up a slipfit.
Notford is offline   Reply With Quote
Old 03-24-2003, 10:07 PM   #29
1FaastC10
1FaastC10's Avatar
where did that hooker part come from?
1FaastC10 is offline   Reply With Quote
Old 04-15-2003, 10:12 PM   #30
bretthan
Damn those ricers
bretthan's Avatar
I don't think shortening frames is prohibited by law, at least not in canada , because you look in the phone book, and there are lots of companies that shorten big rig frames. I'm guessin that its the same for pickups.
1994 Chevy Cheyenne C1500 ext.cab s/box
Nothin special right now, just got a 350 with no cat. converter, and a magnaflow muffler
In God We Trust, Vengeance is Mine, Sayeth the Lord, NO FEAR!
Indian Larry 1949-2004
bretthan is offline   Reply With Quote
Old 04-19-2003, 05:53 PM   #31
chevykid04
4 speed, hurst shiftin
chevykid04's Avatar
yeah i live in wisconsin , they allow quite a bit, except lifting , anyways, i think im gonna look for a swb this summer, then sand it down , redo the bed and tub it , then worry bout the frame, all i need is the funding....
Shane
1970 Chevy C10
chevykid04 is offline   Reply With Quote
Old 04-20-2003, 01:35 AM   #32
dmnall
dmnall's Avatar
well the question I have since I am going to be shortening my frame soon.. I have heard that the strongest way to shorten the frame is use the 45 degree method and bringing in the frame together instead of doing Efab's method... So Which method is better Step Method that Efab used or 45 degree method that I heard that Early Classic used ???
1968 C10 Truck LWB Fleetside
1968 C10 Truck SWB Stepside
1994 K2500 Ext Cab Fleetside
2008 Honda Civic Si *lease*
dmnall is offline   Reply With Quote
Old 04-20-2003, 09:44 AM   #33
Blue Beard
Blue Beard's Avatar
Pickup the classic truck issue, sure to help with the article in it. Maybe its on the web.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 04-20-2003, 10:22 PM   #34
Dreaminator
Dreaminator
Interesting comments. Are you also going to C notch the frame? Mine is C notched with four inch lowered coils and I worry a bit about penard bar and the angle when I really get on it.
The Dreaminator
Daily Driver 1971 Cheyenne 10 Lwb Tilt/Tac 402 .030 TH400.
Dreaminator is offline   Reply With Quote
Old 04-21-2003, 01:48 AM   #35
Jesse 67 c-10
Jesse 67 c-10's Avatar
I would say you had better be a damn good welder before you grind away your welds to try and hide them. just think what could happen if your frame broke while driving! if your good grind the outside, leave the inside and box it good. If its stronger than before, bonus! if its weaker your screwed.
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 04-26-2003, 02:20 PM   #36
TooMany2count
Who's in CHARGE??????????
TooMany2count's Avatar
Originally posted by john j
OK kid, before you start all the cutting and snipping you SHOULD check the law in your state about welded frames!!
cannt say if its LEGAL or not to to weld on the frames BUT it would make sence to me that it should be ALRIGHT to do it because, all the sub-frames under the new cars are WELDED, the frames under all of the older ones (could name quite a few if you like) are welded & IF its not legal then I guess all those companies that makes frames for the street rods & trucks should be out of business cause they're ALL WELDED together and what about all those body shops that do frame repairs on those cars & truck. AS long as its done correctly there WILL NEVER BE A PROBLEM WITH IT, BUT just like any other frame, if it rusts badly the yes replace or repair it NOW....just my 2cents...joe
Send a card to a soldier in Iraq
My Music PlayList
Large Marge
Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE
TooMany2count is offline   Reply With Quote
