Old 01-03-2010, 10:45 PM   #651
VA72C10
VA72C10
VA72C10's Avatar
Re: 1970 VA Longbed Project
Originally Posted by mx574 View Post
looking great man. i got to get out and spend more hours in the garage because i will get insanely jealous when your truck is finished before mine. Keep it up and im liking the progress. Saw those headlights on that "sick fish" joe rogans baracuda, they are nice. Tell me about that accuair elevel-ive never seen it how does it work?
It is a true load leveling (not pressure based...actual height) computer controlled system that monitors your bags, air tank and compressors...
You can pre-set it to a height to raise when you start up, and set three preset heights. Also can manually adjust how you like or dump all...
Check out kevin of LFD (Rockcrln) thread about his 4 door tahoe project...he did an install of the kit with a writeup of the product. If you google it there are several videos of it working...I will put one up when my truck is to that stage...
Originally Posted by 1sik52 View Post
Looking good!
Thanks! Gotta stay ahead of you...you're moving on your blazer project!
Old 01-05-2010, 12:40 AM   #652
phipp13
THE DAMN YANKEE
phipp13's Avatar
Johnathan, you are as methodical as a serial killer! Your truck is one sweet assride!!! subscribed!!!! looks awsome keep us posted. R, The Damn Yankee
phipp13 is offline   Reply With Quote
Old 01-05-2010, 12:47 AM   #653
VA72C10
VA72C10
VA72C10's Avatar
Man, I don't know to take that as a good or bad thing J/K Thanks! Should have some more pics tomorrow...
Old 01-05-2010, 07:42 PM   #654
70k52wd
Blaze-Air
70k52wd's Avatar
It took me a couple of hours just to get caught up on your build. Awesome build. The amount of thought and hard work are showing. Great work Jonathan.
Hope your feeling better.
70k52wd is offline   Reply With Quote
Old 01-05-2010, 07:54 PM   #655
VA72C10
VA72C10
VA72C10's Avatar
Thanks...finally had to get some antibiotics and now I'm doing better. Going to go over and get some more stuff done this week hopefully...
Old 01-06-2010, 12:03 AM   #656
Slick67
Sofa King Crazy!!
Slick67's Avatar
Peppermint, Honey, Lemon and Jack - mix and drink......that will make you right again!! If there ever was such a thing!!! hahaha Lookin great! Keep it going!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 01-06-2010, 10:57 AM   #657
powerline84
Greasemonkey
powerline84's Avatar
looking good man this thing is gonna be sick ill let you park next to me any day lol
1970 cst-10 longbed
speed
My Baby
http://67-72chevytrucks.com/vboard/s...=1#post3113923
powerline84 is offline   Reply With Quote
Old 01-06-2010, 03:45 PM   #658
brian69longbed
brian69longbed's Avatar
Pictures!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=354115
brian69longbed is offline   Reply With Quote
Old 01-06-2010, 06:13 PM   #659
70k52wd
Blaze-Air
70k52wd's Avatar
After doing the blocks to center your tires in the wells, and having to remove the rivets, and doing the exhaust pass thru's. Would you think about getting a aftermarket center xmember if you had to do it again? Do the aftermarket ones center the tires? just curious.
Old 01-06-2010, 07:37 PM   #660
lolife99
67-72 parts collector,…
lolife99's Avatar
No.
But you can add the spacers just like VA72C10 did.
Old 01-06-2010, 07:47 PM   #661
VA72C10
VA72C10
VA72C10's Avatar
No.
Like lolife99 (our resident suspension expert ) said you'd still need the spacers....other than Porterbilt's setup where he lets you change the length of the arms. He's working on one with different mounting points also. That's the only thing I would do differently....go with the Porterbilt crossmember and trailing arms on my next build....but that one will be LOWER
Old 01-06-2010, 08:01 PM   #662
lolife99
lolife99's Avatar
Just curious,... If you could do it again,... wouldn't it be easier to just "relocate" the complete trailing arm crossmember back,... the require distance?
I believe that's the route Porterbuilt is going.
That way, he can build all his tubular trailing arms are the same length.
And,... I'm just a moderator.
No expert here.
Old 01-06-2010, 08:02 PM   #663
VA72C10
VA72C10
VA72C10's Avatar
Sounds.....interesting.... Thanks for the encouragement.
Thanks man
Originally Posted by brian69longbed View Post
Pictures!
Soon
Old 01-06-2010, 08:08 PM   #664
VA72C10
VA72C10
VA72C10's Avatar
Yeah, that's what I was thinking from his thread on them. Like I said, if those had come out earlier I'd have them....but I'm extremely happy with how mine turned out both in looks and functionality. Basically this whole build is supposed to be factory did plus a little refinement to make it better. Love the body lines...just smoothing them out....great rear suspension....just lower and tighter....etc....
No expert here.
Come on, don't sell yourself short. You've helped a ton of us out. Thanks!
Old 01-06-2010, 08:44 PM   #665
SCOTI
SCOTI's Avatar
No expert here.
From what I remember, PB's revised TA mounts will come w/2 sets of holes. One set is OE location; 2nd set is shifted back. I opted for the spacers so I could vary the positioning @ any time* vs. shifting the c.member back.
*pending bag mounting & notch area
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-06-2010, 09:13 PM   #666
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I cant believe ive never read your build!!! Going to be a sick truck when your done! Whens the projected done date? You have sold me on a few things for my truck, holes in the crossmember for exhaust. (Could one cut the holes without a plasma cutter easily?) I wanna do mine but not a fab expert but have a welder and access to good welders (actual people lol). And im doing my frame in 'hammererd' it looks awesome! Cant wait to see it done. Keep it up. If i knew I had that much $ in my truck. I wouldnt add it up! I thought I had lots in mine LOL. Not even a fraction.
John
1999 Toyota Tacoma 4x4
Old 01-06-2010, 09:23 PM   #667
VA72C10
VA72C10
VA72C10's Avatar
Welcome aboard...it's never too late to join
I'm sure it could be cut w/out a plasma but it's much easier that way. Thanks...I'm happy with how the hammered finish turned out.
Old 01-06-2010, 10:59 PM   #668
oldblue1968chevy
Couldnt possibly do it with a hole saw...to thick Id guess......im running 2" exhaust but would like the option to go bigger 2.5 or something.
Could get a crossmember from junkyard and take it to somebody with plasma cutter...whyd you go oval vs round? I cant wait for warm weather so I can spray paint. 25* with snow tonite isnt appropriate weather for spray bombin'.
Looking forward to your finished truck.
John
Old 01-06-2010, 11:20 PM   #669
VA72C10
VA72C10
VA72C10's Avatar
Getting an extra crossmember sounds like a good idea. I actually went with the oval because the center hole is an oval so I wanted it to match. Also spaced out the pipe we used to line it the same as factory to try to make it look like a factory job.
Old 01-07-2010, 11:20 AM   #670
oldblue1968chevy
crossmembers are the same67-72 as long as its trailing arms, correct?
John
Old 01-07-2010, 08:52 PM   #671
VA72C10
VA72C10
VA72C10's Avatar
Yes, all the trucks I've seen have the same....other than a carrier bearing mount on longbeds...
Old 01-08-2010, 10:24 PM   #672
VA72C10
VA72C10
VA72C10's Avatar
Since you guys love pictures as much as I do...here are some buckets I'm hoping to pick up next week for the truck.
Old 01-08-2010, 10:31 PM   #673
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Those are nice lookin. What are they from/for?
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 01-08-2010, 11:02 PM   #674
VA72C10
VA72C10
VA72C10's Avatar
they are aftermarket designed for hot rods. They are lowback buckets approx 24" tall plus the brackets...I will modify them so they fit right underneath the window
I won't have any updates this weekend because I'm traveling to Florida. My wife's grandfather has cancer and has just decided not to take any more Chemo because the cancer is still spreading. So we want to visit with him before his health goes further downhill. Going to leave in a few hours, drive all night/day and see him tomorrow. Have other family near Tampa and then will head back Sunday so I can be back at work Monday.
Old 01-08-2010, 11:21 PM   #675
brn agn
brn agn's Avatar
If you have any problems or need to stop for a break going down or coming back, give me a call. We are about 30 miles off I-95 I'll PM you my new phone number.
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
