Old 01-02-2010, 01:54 AM   #1
383tbi
88 rear end in 87
Hi new b from Houston Tx.Had question for you guys.As the title says Im in the process of completing the 88 rear end install in my 87.I went ahead an welded the leaf spring perches on the bottom of axle since I m dropping it also.My pinion angle is set -3 degs.The problem i have is the pinion yoke is different.The one on the 88 rear end is bigger then the 87 rear end and is not swapable.What do you guys think is the easiest way to fix this problem.I was thinking about cutting off yoke from drive shaft and getting right one welded on.Also how much in and out slack has to to be in the trans yoke with the truck on ground.I have about 3/8 of an inch.Thanks in advance
383tbi is offline   Reply With Quote
Old 01-02-2010, 02:43 AM   #2
cableguy0
Re: 88 rear end in 87
does the driveshaft have a slip yoke and carrier bearing? if the driveshaft has a slip yoke in it aside from the one in the trans your fine. what do you mean by the yoke is too big? your current u joint doesnt fit? or the driveshaft is too long now? if its just the u joint thats an easy fix with an adapter u joint.no need to cut anything up or change anything else.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 01-02-2010, 09:27 AM   #3
383tbi
No carrier bearing.Its a shortbed.On the pinion yoke yes its bigger as in the u joint cups are to small and of coarse the strap bolts are to but not worried about those.So they sell adapt u joints with 2 different size cups.If yes then where.I will try local autoparts first.
Old 01-02-2010, 10:59 AM   #4
OJOE
Crew Cut
OJOE's Avatar
yes that is all you need. just take the 2 u joints to napa auto parts and show them what you want. and WELCOME to the board from montgomery al
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 01-02-2010, 12:08 PM   #5
383tbi
Appreciate the welcome.What do think on how much in and out slack the trans yoke needs to have.
Old 01-02-2010, 12:33 PM   #6
78-5.3
78-5.3's Avatar
appreciate the welcome.what do think on how much in and out slack the trans yoke needs to have.
3/4 - 1 1/2 in the most
78-5.3 is offline   Reply With Quote
Old 01-02-2010, 03:34 PM   #7
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Is this a 1/2 ton or 3/4 ton? I'm just curious, as I put a 91 1/2 ton pickup rear end in my 85 and the original u-joint fit the 91 pinion yoke just perfect.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 01-02-2010, 07:53 PM   #8
383tbi
My truck is a half ton and supposely the 88 model rear end is also from a half ton.Its a 5 lug 10 bolt
Old 01-02-2010, 08:22 PM   #9
cableguy0
there were 2 different u joints used in the 87. dont remember the numbers on the joints but either way as stated you can get a conversion joint its not a big deal any decent auto parts store should have it on the shelf
Old 01-03-2010, 02:02 PM   #10
383tbi
Ok thanks for the replies.I will grab demensions on both sides and go out and look for one.
Old 01-03-2010, 02:43 PM   #11
nlped
nlped's Avatar
When I put the '96 rearend in my '87 I used a Spicer 1350 to replace the stock 1330 u joint. If I'm not mistaken, the 1350 is the same one used on the 4WD in '87...right?
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 01-03-2010, 04:20 PM   #12
383tbi
Does that 1350 have 2 different size cups.Cause that what Im going to need.
Old 01-06-2010, 10:29 PM   #13
383tbi
Ok after doing some researdh I found that my original 10 bolt pinion yoke is for 1310 series u joint.The pinion yoke on the 88 rear end thats in my truck now is a bigger 3r series yoke.Totaly different.They are both 30 spline.Ok you would say why don t I just put on the original 1310 series yoke on the 88 pinion.Ok 1 for some reason it don t want to go on,2 the part where the seal rides on is smaller than the 3r series yoke.I thought all 10 bolt 8.5 30 spline pinion should be the same.Can you guys give me a hand here or point me in the right direction.Thanks
