what do i need?
im looking to get my truck ready for a 700r4 i need to know what i need my truck had a 350 turbo, need to know everything such as, can i use my cross-member or do i need new one. next question is shifter linkage im running ididit column with column shift if someone is running this set up and would like to share there set up that would be great thanks.
![]() Join Date: Feb 2001
Re: what do i need?
Bump...
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
![]() Join Date: Jul 2006
Re: what do i need?
do a title search for 700R4 and you will find lots of useful info.
-you can move your crossmember back and redrill -need a longer speedo cable, available at any parts store ask for 4wd of same year -shift linkage can be adjusted or an aftermarket, I used a CPP universal -cooler lines can be reused -driveshaft may have to be cut depending on short or long tail TH350 -700r4 dipstick (88-up chevy/gmc truck work great). -TV cable, universal are the best in my opinion because you can adjust the sheath and cable or go 88-up again. (research this) -trans pressure test gauge -speedo gears -lock-up wiring (research this) that's everything I used.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
Re: what do i need?
thanks this should get me in the right direction
