Old 01-07-2010, 03:20 PM   #1
blackdiesel
blackdiesel's Avatar
Re: '55Chevylover's 55stepside build up
Originally Posted by Tri5Nerd View Post
It's all in how you prep the metal, if you grind or clean all the rust off and don't use the prep solution it will peel, if you give it something to hold on to it will last a long time and you can paint over it.
Tri5
My frame was freshly sandblasted. if i would have known i would have just used a catalized paint. instead of a just brush it on straight out of the can paint....
Or if i would have sprayed it down with water and let it set a day or two to let it build up a layer of surface rust it would have been ok. POR stands for Paint Over Rust, which is what its designed to do. not POCM
on all my other projects i use a black acrylic enamel. havnt had any problems with the last 3 or 4 done that way.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 01-07-2010, 05:09 PM   #2
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
You are correct about painting over rust, they say to lightly brush the heavy rust off, not all rust then prime with their eching primer, then brush on, they really don't recommend spraying.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
