Badass
2nd gear face plant
ok when im getting on it.run threw first gear gets about up to 3k and u hear the primary's kick in and then it shifts at 43xx and then just falls flat on its face and slows down then gets back in it????????????
its a stock 305 with a quardajet with a th350
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() Last edited by 3r!c84; 01-05-2010 at 11:02 PM. |
Re: 2nd gear face plant
i've been having the same problem since i bought this truck a few months ago. i have a 700r4 though. i havent figured it out either.
fuel pump?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
Mine has been doing the same also factory 305, th350. I was low on tranny fluid put some in and it has been good for a while but it's back again. Could it be dirty oil, filter or a vacuum problem? I haven't looked into it. Household work truck.
yea my 77 dose that idk the rpms but when you get the four barrol open in
2nd and are pulling bout 75 mph it just dies then you shift and then it pics rite up ill you hit about 110 or so and it dose it again mines a 350/sm465/3.73s i was gonna rebuild it sooner or later and was gonna try a bigger needle and seat BUT... i can say 1 thing back when my carb wont adjusted (it was about 6 turns out on each side) it would pull hard past 100 and start climbing towards 0 all this happened when i had my carb adjusted
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin 79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s 81 mercedes 300d 25 MPG 77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded" 73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091 '77 chevy trucks. built to stay tough. life is short build a hot rod ![]() Last edited by big10ratrod77; 01-06-2010 at 06:35 PM. |
mine used to do that and i put a edelbrock 650 on it and got rid of all the extra vacumm lines a junk and it runs great now, not bad for an old 305
stock
i think i used this one
http://www.summitracing.com/parts/ED...odel|Performer |
Badass
ohhhh u shoulda got a intake off of CL they are cheap like 50$ at the most
hell i got a preformer RPM airgap for cutting my friends grass ![]() ![]()
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
i actually had one i got for $50 and my little brother tried to pick it up and dropped it and it cracked and i already had the adapter in the garage from an another car so i just used it when i ever clean my enginebay up i will prolly get me a new intake
Resident of Here
It could be the fuel filter or fuel pump. Mechanical or vacuum secondaries?
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#15 |
Badass
vacuum secondaries
i could change the fuel filter thats in the carb.it dont have one any where else
#16 |
#18 |
