Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 03-30-2003, 06:39 PM   #1
crossy
Oh,you can't buy that new
crossy's Avatar
engines in N.J. . it's time
garage cleaning time.tell a friend, maybe he'll give you a free beer.
This is a complete NEW GM crate 350 Chevy engine.minus intake. WOULD MAKE AN EXCELLENT DAILY DRIVER ENGINE WITH 4 BARRELL. HasOne piece seal. Only one dealer had them. Built by GM with all new parts . These are fantastic TBI replacement engines or very torquey street 4 barrel engines. No warranty left because of time lapse. Has been safely stored. Nodular iron crank(stronger than cast), new style LT1 PM rods(very strong),Hyperutectic 9.5 to 1 pistons(with current heads).the heads are stock type 350 TBI with 1.94 valves and swirl intake ports . It has a small ,torque type hydraulic roller cam. in it ,about a 40 HP boost over your current TBI engine.This engine will work in any 95 or older pickup and can be equipped with an aluminum 4 barrel manifold.(Edelbrock #2104 and I have one. ). I also have a set of mildly reworked 350 TBI heads that have new 1.94 intake valves and corvette LT1 springs on them. I have a new takeout, Corvette LT1 cam that will kick this up another 25 HP. I saw these engine make 280HP with the cam And head change with stock wimpy TBI on it .If you are not sure whether this will work with your vehicle then email or call and I can tell you. If needed.can be set up to hear run.can be crated & shipped. Engine $1800 FIRM. heads & LT1 cam $495. GM gets $1800+ plus for the basic TBI replacement engine and it is not built half as well as this one. 856-678-7883 before 9PM EST. . Be VERY specific when Emailing please. all4trux@snip.net . located in so. N.J., I may consider smaller parts on trade. hot rod or musclecar. Thanx , DAVE
1984 350 2 bolt, bare block with caps, cast crank may need .010 cut on rods if your fussy..,I have plenty of extra 350 rods around . engine will need first bore only because of water damage from outside storage. engine only had 39K on it .No damage. Block/crank/rods= $95 .I get wholesale parts on rebuild kits and will supply if needed.I do NOT sell the rebuild kits separately.can be crated & shipped. . 856-678-7883 before 9PM EST. Please Be VERY specific when Emailing please. all4trux@snip.net . located in so. N.J.,Thanx , DAVE
This 1966 BARE 396 Chevy ,2 bolt block & caps . casting #3855981 . It is still standard bore and has no ridge on the cylinders.It had 2 sleeves installed quite a while ago and has been run and made 450HP in my car so it was well tested. The date is very hard to make out and looks like B-26-6. it is stamped with a few different sets of numbers on the pad and had a factory screw up (yes, they were humans)it is stamped as a build date of T03I0, so they put an 'I' where there should be a '1'. then it is stamped E//// , they crossed off a wrong letter and ground in an 'H'
then has a 6A135809 on it.well enough about the silly numbers. The block is clean , no other damage or stripped holes. A steel crank , Rods =Std../ Mains=Std. is available only if purchased with block . Block=$125. Block & Crank =$300. Block/Crank and freshly resized rods with good SPS bolts $450. I get wholesale parts on rebuild kits and will supply if needed.I do NOT sell the rebuild kits separately.can be crated & shipped. 856-678-7883 before 9PM EST. PLEASE! Be VERY specific when Emailing please. all4trux@snip.net . located in so. N.J., Thanx , DAVE
This 1964 327 BARE block W/caps & bolts. dated G/1/64 is casting number 3858180 and contrary to belief ,is acceptable in the same place the 870 blocks were used.it only has an 'S' stamped on the front and SC,SD,SK,SL were all corvette codes. This block has NO serial numbers on it anywhere and was NOT decked to remove them. The block is a fresh ,tight .030 bore right now awaiting final hone for your pistons.. BLOCK=$195. I get wholesale parts on rebuild kits and will supply if needed.I do NOT sell the rebuild kits separately.can be crated & shipped. 856-678-7883 before 9PM EST. Be VERY specific when Emailing please. all4trux@snip.net . located in so. N.J., Thanx , DAVE
This is a complete 1969 396 engine that is still standard bore from a Cheyenne Pickup.NOT a tallblock. Everything is numbered and dated correctly even distributor. It cost my friend $1800 to have this engine redone and the knucklehead left the stock pistons in it. It was cooked ,cleaned ,crank polished .balanced Etc. etc.! It has ALL NEW components inside except the pistons, which I am sure is the reason why it has a 'slapping' noise inside with only 1500 miles on rebuild(these pistons were known to crack). Cam ,rockers & springs & pushrods are NOT stock with a .500 lift hydraulic complete comp cams set up. I even have the STOCK air breather and a 69 Q-J carb. I WILL NOT PART IT OUT. even if it has to be bored out this engine could be redone WITH new pistons for less than $500. because nothing else has to be done. I rode in this installed in a 3/4 ton 4x4 and it was an animal. Complete Engine=$1200. I have all the Power steering brackets ,pulleys and even reservoir & belts from this engine. NOTFOR SALE seperately, but purchaser of engine will get offered them. This one can be set up to hear run with advance notice. I get wholesale parts on rebuild kits and will supply if needed.I do NOT sell the rebuild kits separately.can be crated & shipped. 856-678-7883 before 9PM EST. Be VERY specific when Emailing please. all4trux@snip.net . located in so. N.J. thanx ,
DAVE
I might be headed to the truckin Nationals in Sieverville,TN May 2nd with an empty bed so there are posssibilities here. DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 03-30-2003, 06:43 PM   #2
crossy
crossy's Avatar
I priced shipping for someone of the 600# complete 350 to Louisiana from here in N.J. and said it could be done for $300. hope that helps some.
98 Vortec project.
94,3500,6.5L 4L80
Old 04-26-2003, 08:15 PM   #3
rsullivan
how many engines are u selling and if there is mthen one how many do u have left
rsullivan is offline   Reply With Quote
Old 04-26-2003, 09:10 PM   #4
crossy
crossy's Avatar
the list a t the top is current. I have edited it as necessary. DAVE
98 Vortec project.
94,3500,6.5L 4L80
