Old 01-07-2010, 11:55 AM   #26
OhOneWS6
OhOneWS6's Avatar
Re: stock gas tank and saftey???
Originally Posted by Longhorn Man View Post
a stock height truck at a stop, gets rear ended, from a car doing more than 25 - 30, the car will go UNDER the truck. I have been in 2 accidents like this.
I can vouch for that as well. This was ~25 MPH into the back of a full size GM SUV. Guy I hit had no brake lights and was stopped at a green light. Car went right under the bumper. Happened Sunday.
OhOneWS6 is offline   Reply With Quote
Old 01-07-2010, 12:28 PM   #27
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i was with a buddy about 12 years ago or so, in his 69 C/1500 LWB GMC. Stopped at a light. Jake didn't have his foot on the brake even, sitting in gear, clutch to the floor. A Ford Escort went under the rear bumper. The Escort's front bumper hit the rear axle in Jake's truck, and the rear bumper of jakes truck was sitting where the glass used to be in the front of the Escort.
Old 01-07-2010, 12:35 PM   #28
yote1234
yote1234's Avatar
Re: stock gas tank ans saftey???
Originally Posted by big_al_71 View Post
I rebuilt my truck completely and I did not find it necessary to move my gas tank at all. The only reason why I would move it is to gain some room but I chabged my mind so I left it as is.
i agree. my seat doesn't fold foward so im keeping the in cab tank... a good use for waisted space
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 01-07-2010, 05:44 PM   #29
StingRay
StingRay's Avatar
A tank mounted at the rear outside of the pass compartment is what most cars have had for a long time. The Pinto problem is that the top of the tank was the rear floor for the pass compartment. When it ruptured it could be to the interior. It's a bit harder to rupture the old truck tanks because of their location but when it does happen it isn't pretty. I have had the tank in the cab for years and have always had the intent to move it. I still plan to do it. I'd much rather have a tank rupture easier at the rear 8 ft behind me than inside the cab and have the gas all over me. The 73-87's problem was that the tanks are outside the frame rails, ouside the cab mind you but still right under your butt. 73-87 tanks are very vulnerable. The best place is between the rails midship failing that between the rails at the rear.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 01-07-2010, 06:58 PM   #30
rsavage
rsavage's Avatar
StingRay,
Although it is logical that a tank would be safer between frame rails under the bed as opposed to the cab, the vehicle has to be engineered so that in a rear end collision, other parts of the vehicle do not puncture the tank. I was rear ended by a car and it went right underneath the S10 blazer I was in. The replacement tanks that are most usually used are those that hang down fairly low. A collision like I experienced would have cleaned it off. A much more recent example of rear mounted gas tanks exploding can be found in Ford's Crown Vic used by many PD's. Since our old trucks weren't engineered for a below bed tank, if I were going to move it for safety reasons, I would use a fuel cell.
Watched the Junior Tournament from your city - great tourney and your city did a great job. It comes to Buffalo next year which is 20 miles from me.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-07-2010, 07:45 PM   #31
Jebb1978
Jebb1978's Avatar
I actually moved my tank out of the 59 because it was the cool thing to do. This was back when I had virtually no budget and I put a fuel cell in the bed. I failed to see the benefit of it in use and mine didn't look so slick anyways, now that the truck has been down to frame, I replaced the in cab and will run it that way. My 67 has the in cab tank and I have no plan of changing it, with the correct gas cap on it fumes are a next to nothing. Like others have said if General Motors designed the truck to have it outback that's where "The General" would have put it. As I get older I am learned to appreciate the way things came more and I want my old truck to be like an old truck. That's my thoughts anyways.
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 01-07-2010, 08:56 PM   #32
brad_man_72
the boat guy
brad_man_72's Avatar
fuel cell behind the axle. better weight distribution and a lower center of gravity. great during the summer, i have to hold the gas nozzle in order to fill the gas tank, not much fun when its -13 windchill today.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 01-07-2010, 09:05 PM   #33
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
I have to agree with the majority that the tank is fine where it is at. It's cool Dad let you leave it. It's cool to move it too if you want the space and such. There are going to be the terrible instances as was said but an impact that would get that far into the cab to cause such a bad rupture is very rare. I have seen lots of them in junkyards that have been t-boned, rolled and broadside slides into poles, with the tanks damaged but I don't ever remember seeing one that was burned from such instances.
One more advantage that I don't think anyone mentioned is gas theft. The lowlifes around here have been just punching large holes in tanks to steal gas anymore so the in cab tank setup has less risk of losing your fuel and a tank too. I can remember the local news in the summer of '08 when gas was over 4 bucks that most all cars in one car sales lot was vandalized in this manner.
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 01-07-2010, 10:53 PM   #34
Rob H.
Rob H.'s Avatar
I like the in cab tank, I've had to replace so many under the bed tanks because of rust or because they got a hole knocked in it from a rock or a piece of metal thrown up from the road. I've seen one truck that I can remember that was burned that was contributed to the in cab tank. That being said the owner had a rag stuffed in it for cap and smoked, you can see where it was two mistakes of human stupidity and not the design of the truck. I've seen them Tboned and the tank smashed and very little leakage and no fire. I'm sorry about the ones that were lost in the accident mentioned, but as said before it was a fluke.
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline   Reply With Quote
Old 01-08-2010, 01:42 AM   #35
tim21391
tim21391's Avatar
just think the tank wont get corrosion from the road grime..
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
