Old 01-08-2010, 02:28 PM   #1
RonT
Front brakes
Installed a 82 front X member on my 69 c 10 frame and installed 3 inch drop spindles from Summit, new rotors and calipers, now when install pads rotor will not turn by hand, rotors 1 1/4 etc any ideas how to correct?
Ront
RonT is offline   Reply With Quote
Old 01-08-2010, 04:10 PM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: Front brakes
Ront
You may have the calipers for a 1" rotor and not the 1.25" rotor. Both were available on the truck so it is easy to get the wrong parts.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-08-2010, 07:10 PM   #3
RonT
Re: Front brakes
thanks for come back. changed calipers and NAPA went thru book said this was the correct part, if I re install old rotors , hub turns. rotors have some wear but very little,
I keep finding that their is different rotors J 1 etc and jb 4 5 etc , I havent been able to find out difference yet, as this could be problem not sure, but susposly I have the correct caliper for 1 1/4 rotor
Old 01-08-2010, 07:55 PM   #4
68 TT
68 TT's Avatar
Re: Front brakes
Maybe the pistons in the calipers are not retracted enough. A c-clamp will do the job to fully seat the piston so the pads are not dragging so much. It should move pretty easily.
I have heard there were some thicker pads available that were used on the 1" rotor so it is possible you have too much thickness for it all to work right.
Old 01-08-2010, 08:08 PM   #5
RonT
Re: Front brakes
piston all way in have clearance on inboard pad outboard pad is the one that is giving me trouble, and you could be right about pad, may be little thicker than it should be, or rotor may be little over tolerance. thanks for help any more ideas keep them coming
Old 01-08-2010, 08:21 PM   #6
68 TT
68 TT's Avatar
Re: Front brakes
I still think you have the 1" caliper and not the 1.25" version. I wish I had some dimensions for you to check but I don't have anything.
I would be inclined to take one back to the parts store and compare it to another that is supposed to be right.
Old 01-10-2010, 07:09 PM   #7
mickman77
mickman77's Avatar
Re: Front brakes
I have the same problem on my '77 K20 on the driver side. New pads are tight but turned .004 off the rotor and then the outboard pad is hanging up. May have to put a shim between the rotor and hub.
'77 K20 LWB 454, NV4500, NP205, 4.10's rollin on 33's passin everything but a gas station.
mickman77 is offline   Reply With Quote
