Always a work in progress
Help me please!!
I finally got out in the garage to trace some wires and find out what was going on. I hooked up the wiring according to the diagrams that I have and replaced the dead battery with a new. I could bump the motor over with a push button starter button hooked up, but got nothing when I tried to start it with the key. Well, it got cold and I did not want to go in the garage without heat so it sat for a couple weeks. I went out there today and found out that the junction block up on the firewall wasn't working. I had power to the bigger terminal but nothing on the smaller post. I hooked up a jumper wire and I could turn it over with the key. My question, is there a certain way to bolt it to the firewall? Is there some sort of a connection on the other side that I should have it hooked up to? Can I elminate the junction block all together or just put all the wires on the 1 post?
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
Re: Help me please!!
I think there is a piece of metal that connected the two together. See if its got a poor connection.
1977 Chevy Cheyenne 2wd SWB |
6.0 powered square
the red spot is were the junction box was
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
In my best Loyd voice- So you're saying there is a chance!?!(that I don't need it.
There is no power getting to the other post, What connection are you talking about, the actual post or behind it?
6.0 powered square
then you won't have any heat or air, but I don't have one because I running a universal harness
Flamingbig10- Thanks for the input.
I would like to keep the heat bc it is cold right now. Is there more than just bolting it to the firewall and hooking it up to work properly?
