Old 01-10-2010, 10:28 PM   #1
Sicboy
Sicboy's Avatar
Heater Control Levers help...
Just ordered a set of heater control levers to replace the broken levers in my '66 C10. I removed the screws that hold the heater facia to the dash, thinking that it would slide forward through the dash, but it didn't move forward or back. What else is holding the unit in place, and does it pull out through the dash or from behind? Thanks.
Gary
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482
Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!”
- Hunter S. Thompson
Sicboy is offline   Reply With Quote
Old 01-11-2010, 12:57 AM   #2
Captainfab
60-66 Nut
Re: Heater Control Levers help...
There is a brace that goes from the heater control down to the lower edge of the dash....just one bolt. Then it goes to the inside of the dash.
