01-11-2010, 02:28 PM | #1 |
Gremlins!!
My truck runs great and I've put a couple thousand miles on it lately. It just started dying when i go to stop at a light or when I am backing out of the driveway. Then it starts right up without a problem. I don't think it's a fuel problem since the engine doesn't rotate more than one time before it starts again and I don't have to pump the gas..... any ideas?
01-11-2010, 04:32 PM | #2 |
Re: Gremlins!!
check vacume lines, that would be my first idea
btw nice avatar
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
01-11-2010, 04:44 PM | #3 |
Re: Gremlins!!
gremlins rock
01-11-2010, 05:08 PM | #4 |
Between Trucks...
Re: Gremlins!!
What's your idle speed set at?
Beat it to fit, Paint it to match... |
01-11-2010, 07:29 PM | #5 |
Re: Gremlins!!
01-11-2010, 10:36 PM | #6 |
Re: Gremlins!!
If you have a hei distributor?your feed wire might be losing juice when you step on the brakes?
72 2wd lwb cheyenne super youngest son.green/white 72 2wd lwb cheyenne super oldest son.green/white 71 4wd 3/4 cheyenne super frame off manderin copper / white 4 inch lift. FINALLY DONE / SOLD 72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856 |
01-12-2010, 04:50 AM | #7 |
70 Chevrolet=Obsession
Re: Gremlins!!
I once had a problem of my truck dying at stop lights or at the bottom of off ramps. I checked out my engine and found a cracked vacuum line. Fixed it and the problem went away.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
01-12-2010, 09:37 AM | #8 |
Re: Gremlins!!
01-12-2010, 11:51 AM | #9 |
Active Member
Re: Gremlins!!
A little more info would help like engine, transmission, hei or points.
If it was running good before and nothing was done to the engine, then look for vacuum leaks as GreaseM mentioned. Carb base gasket and middle gaskets on quadrajets are know to come loose. Check all vacuum rubber hoses and flex and unflex them to see if you can find cracks. If you have points, recheck the gap. I'd also check to make sure it's not flooding. Sometimes too much fuel especially during low idle will cause the engine to die. Quadrajets had problems with leaking plugs. Check for smoke when you first restart it. |
01-12-2010, 07:18 PM | #10 | |
Re: Gremlins!!
