Speedo?
Here's the deal guys...this past Saturday I decided to lower my truck, 5/6 drop. I was running a 255/70/15 tire all the way around which we all know is too tall for a lowering job like that. Decided to run 245/60 and 275/60/15 in the rear. Now for some reason I lost my mph. My speedo shows 70 when in reality I'm doing 55-60.
Any inpuit would be greatly appreciate...btw its a 1977 c10 LWB. My 2 questions are what caused this, how do I get my top speed back? |
Re: Speedo?
Not sure if this help guys but I can safely rule out the cable because while my mph gauge is showing 70mph my rpm gauge is at 2300 2400rpm. In reality I'm only doing about 60mph. I will get a more accurate reading on my way back home using my gps which is 99% accurate in all my other cars untill then let me know what you guys are thinking, if anything comes to mind.
THX. |
Re: Speedo?
![]() Last edited by MobSled; 01-13-2010 at 11:28 AM. |
Another Day, Another Dollar
Re: Speedo?
my spedo cable has done some funny things in the past while on a straight stretch of road. it has started to "jump" 0 - 160 and then to 100 and then all the way around and then back down.... etc.
i would yank you spedo cable and make sure that there are no crazy bends, as well as lube er' up with a touch of graphite. bigger tires in the rear would suggest that the spedo should be reading lower speeds if anything....
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
Re: Speedo?
Well that's just the thing I went from a 255/70/15 tire in the back to a 255/60/15...I guess I could be missreading my rpm gauge. On a 350/350 combo with a stock 77 rear diff, while cruising down the highway at 65mph where should my rpm be?
Re: Speedo?
Depends on the axle ratio. If its a 373 it might be 2800 rpm or so.
1982 K10 SWB 1987 V20 - Sold - Doh! |
Re: Speedo?
So 70mph 2300rpm doesn't sound right at all?? Sorry for all the noob questions fellas I got into the muscle scene about 3months ago. Another question is what's a healthy rpm I can take a bone stock 350 up to?
Re: Speedo?
No it really depends on your axle ratio, what I said is close for 3.73, but if you have a 3.07 ratio that would be correct.
Re: Speedo?
4500 RPM is pretty safe max rpm.
Badass
Re: Speedo?
you went down in tire diameter so it will throw off your speedo.just like changing your rearend gears
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
Re: Speedo?
So how do I go about recalibrating my speedometer cable its showing 9mph faster then what I'm actually driving.
Badass
Re: Speedo?
get a diffrent size speedo gear.its on the tranny on the drivers side.at the tail of the tranny.you insreww that and a gear comes out.you can go to gm or a parts store might have them and get a size smaller or bigger(i dont know what way to go)but ask them they will know
