Closed Thread
Old 01-14-2010, 02:56 AM   #651
63 extreme low
63 extreme low's Avatar
Re: What did you do to your truck today?
Hey Scoti how do you quote like that with my pic? And my first suggestion would be to find a big back window cab! Just a lot of metal work on the inside, not that hard just very time consuming. Should have tried to find a junk cab to get the inner panel from. I will try and find the pics of the inside.
63 extreme low is offline
Old 01-14-2010, 11:08 AM   #652
greg65
greg65's Avatar
I went and picked up my cab after having new floor sheet metal installed. There is still some body work to be done before it is ready for paint. We went ahead and set the cab on my frame. It has been eight years since I took it apart and I have almost forgot what it looks like with a cab. It was too late to get any pictures last night but will try to get some this weekend.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline
Old 01-14-2010, 11:22 AM   #653
SCOTI
SCOTI's Avatar
Actually, I just hit the quote button when reading your reply (I'm not puter savvy enough to do it on my own ).
My plan was to get an 'inner' cab skin from the upper seam down to the area where it 'rolls' under adjacent the gas tank & to the doors each side. I figured splicing it together .250" below the OE upper seam to keep things from warping when welding it up.
Since there are multiple ways of doing the job, I like to see if someone has done something different that allows for a 'better' (easier, more consistent) finished task.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now
Old 01-14-2010, 12:34 PM   #654
70 Suburban
Rods
if you removed the entire rear panel like i did you can take off the inner from the spot welds. more work but looks factory. I drilled all the welds at the door and rear and the window. then removed the whole panel. you can see from my what it looks like when you removed the back.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline
Old 01-14-2010, 12:57 PM   #655
SCOTI
SCOTI's Avatar
Definitely more work. How many spot welds do you think there were? Since it will get body-worked anyway, cut & splice gets the job done faster/better for me.
I'm not sure what you were trying to say in bold??
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is online now
Old 01-14-2010, 01:31 PM   #656
70 Suburban
Rods
not sure why its in bold there?... its not on mine. i did it to remove the rear for my extended cab. if someone was goin to take the time to install the inner panel from another truck. i think it would make it ezer to remove.
Old 01-14-2010, 01:57 PM   #657
SCOTI
SCOTI's Avatar
I put it in bold because I wasn't sure what you were trying to say.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is online now
Old 01-14-2010, 02:05 PM   #658
70 Suburban
Rods
lol oops. I have some pics on my build thread that shows the rear panel removed
Old 01-14-2010, 02:20 PM   #659
63 extreme low
I agree with 70 Suburban that would be alot easier!
Old 01-14-2010, 02:25 PM   #660
70 Suburban
Rods
ha......
Old 01-14-2010, 02:37 PM   #661
MountainGoat1966
I finished putting a steering knuckle back together and brake shoes on that side, then moved the truck to a spot where it'll be easier to do the other side.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline
Old 01-14-2010, 04:06 PM   #662
63 extreme low
new cab corners!! not today but it is the last thing I did does that count?
Old 01-15-2010, 01:14 AM   #663
sams60gmc
sams60gmc's Avatar
Today I pulled the long bed off my truck got it loaded on a trailer to sell tomorrow. Sorry to see it go and for so cheap but I had no where to put it and needed to make way for my short step bed and tube back half.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 01-15-2010, 01:31 AM   #664
SCOTI
SCOTI's Avatar
I picked-up my fuel fill hose (it was required to finalize my tank fill piping). Now I can finish that tank related stuff this weekend & mark it off the list.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is online now
Old 01-15-2010, 02:20 AM   #665
MXmaniac
MXmaniac's Avatar
Put shocks on all four corners.
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline
Old 01-15-2010, 03:10 PM   #666
Chevy Fleetside
Chevy Fleetside's Avatar
I pulled the carrier out of the diff becuase I was going to swap in the carrirer from my 4x4 seeing it was a posi diff. I found out I have 3.08 gears in my truck and the 4x4 has 3.73 so I don't think the ring gear is going to swap on to it and work, so I put the carrier back in so I can bust the yolk nut loose so i can change the seal some day/.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 01-15-2010, 07:57 PM   #667
rendus
rendus's Avatar
I patched the front of the drivers side inner fender on my 66 today. No photos as the welds are snotacular! First welding I've did in 23 years.
I'm quite pleased with myself.
rendus is offline
Old 01-15-2010, 09:32 PM   #668
62 Bowtie
62 Bowtie's Avatar
tore out my old bedwood I was surprised at what actually holds the bed down. The bolts actually go through the wood to the frame. I'm afraid to over tighten the new bolts for fear of splitting the wood. Also see new wood in waiting
62 Bowtie is offline
Old 01-15-2010, 10:22 PM   #669
Rich 5150 69
Rich 5150 69's Avatar
So what`s your plans for coating the wood `62...?
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 01-15-2010, 11:38 PM   #670
62 Bowtie
62 Bowtie's Avatar
In the March 09 issue of Custom Classic Trucks there is a 50 Chevy. The guy used Boiled Linseed Oil on the planks which actually soaks into the pores of the wood and provides good protection and leaves a satin finish I'm not fond of the high gloss so if you happen to have that issue or look it up if it's good enough for his truck then I'll use it. Mark-K also has a write up about it.
Old 01-16-2010, 12:12 AM   #671
Envy
Envy's Avatar
My CPP drop crossmember came! gonna put it on sunday
Envy is offline
Old 01-16-2010, 12:36 AM   #672
sams60gmc
sams60gmc's Avatar
Today I did a little bit of work to the backhalf. Then I threw it under my new bed and put the gas tank between the rails just to check it out. Looks so sick. I want it done!! Probably won't run a floor in the bed for a while just cuz I like to see my handy work. Then I dropped my old bed off to the new owner. I was happy to see when I pulled up a short bed Chevy with no bed. I was happy because for the price I sold it for I was scared it was going to get made into some sketchy trailer and not be used for what it was. He was going to make it a short bed and put it on. He had a pretty nice body shop and I think it was for a customer. He didn't need the tailgate and said I should have left it at home then I asked if I could pull it off and he said for 20 bucks lol. I left it. PICS!
Old 01-16-2010, 07:06 PM   #673
ravens65
ravens65's Avatar
We ran the wires for the back of the truck and installed the loom. I've been busy with a new job and haven't had any time to work on my truck. I had a good helper today ( my 10 year old son , the youngest ) he crawled up under the truck like he knew what he was doing. it does my heart good to see him so excited to help dad with the truck . looks like we have a gearhead in the house. I didn't get much done explaining what to do to him, but...if you have kids please get them involved in your build. there is alot of bad things to do as you grow up , but if they are into rodding it gives them a positive outlet for all that extra energy that they have. its also a good way to bond with them!!!! they grow up so fast! notice that the wire comes thru the bed for thru 41-48 tail lights that are mounted in the fenders
If it has tits or wheels its gonna give you problems!!!
ravens65 is offline
Old 01-16-2010, 07:29 PM   #674
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Looks good Eric. Keeps them boys busy. Hows the wifey?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline
Old 01-16-2010, 09:45 PM   #675
corymcrae
replaced a broken push rod in my 62 c10 283, thank god it wasnt anything too serious like stuck valve or broken spring.
corymcrae is offline
Closed Thread
