HID conversion on 84 chevy with dual headlights anyone done this need tips
Hey just wanting to do this conversion wondering if anyone ouyt there has done it and has some advice or some tips and maybe what kits has worked best for you guys some pics would be cool also thanks!
84 3/4ton swap 4x4, 409sbc 37x13.50 toyos 8 inch superlift ![]() 2007 2500 HD, 10-12 cognito lift, 38x13.50 toyos soon to be boosted via rearmount system |
Re: HID conversion on 84 chevy with dual headlights anyone out there done this need t
Most of the monte carlo guys i know use these http://www.spitzkraft.com/detail.php?item=10&numlow=1 But having a lifted truck why not buy a off road bumper and mount some off road lights in it.
#3 | |
86 C10
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold ![]() |
i would look and see if hella makes a replacement housing for your size head light and just find a nice HID kit i would get 4300k max of 6000k after that your are loosing your light in favor of color
Squarebody Aficionado
http://www.classicgarage.com/16rehe.html
this is what i have on my truck i would get you a picture of them on the actual truck but my truck is in the body shop right now. You can only buy 2 because they will match your highbeam bulbs you have in there now. I too wouldnt go with anything higher then a 6000k bulb on an hid kit. those h4 harnesses arent worth it because by the time you buy the harness and the bulbs your more into it then buying an HID kit that is just plug and play. |
ya i plan on picking up the h4 housings on ebay and prolly just gettin a 100 dollar ebay hid kit i dont wanna go to cheap on the kit i heard the really cheap ones burn up i just wanted to get some advice. and as for the off road bumper and lights thats not really my style i like the stock bumper i dont like a bunch of extra addons and stuff plus its a pavement pounder it never goes off road lol
3/4 Ton Rodder
Can someone explain HID and the conversion process and parts to me please?
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. |
#8 | |
Re: HID conversion on 84 chevy with dual headlights anyone done this need tips
I bought the h4 headlight conversion kit from lmc and then bought a cheap hid kit from ebay.mine are 8k
i need to do this but im confused on where to start... any help here
http://www.classicgarage.com/16rehe.html - for the headlight housings
http://www.ddmtuning.com/index.php?p...parent=85&pg=1 - for the hid's this is what i just bought a couple days ago for my 84. great pricing at both places and the hid's have a lifetime waranty. (spend the extra $20 for the digital slim ballast version. lasts longer and better quality) |
i just bought the h4 housing and an hid kit from xtremehids.com
1986 gmc sierra....http://67-72chevytrucks.com/vboard/a...hp?albumid=622 |
here are the hids i bought. they are 6k. pics are from my cell so they aren't great.
Guys, I can make this really, really simple for all of you.
1. Just call Sinister Autosports at 317-870-7570, and ask to talk to Mike (there's only one Mike there). 2. Tell him you saw pics on the internet of a '78 Chevy blue monster truck with HID's that he did. Tell him the make, model, year, and headlight configuration on your truck, and tell him you want to buy the kit. 3. He will sell you all the stuff you need- Bulb housings, HID bulbs, HID ballast, wiring, everything- plus he'll give you directions on how to install it, or you could just take it to any local shop and have the kit installed. 4. This is a GOOD kit. Bright as hell, good quality stuff, tried and proven by a bunch of people around here on many different classic cars and trucks. Should be about $500 for everything. Take it from me, and save yourself the guessing game that comes with HID's. Trust me, there are hundreds of brands and many MANY of them are TRASH, not real HID's, come from friggin' Siberia or Peking or Louisville, and break on sight. Hope this helps. |
#15 | |
With HID's you use the new fuction of bulbs but with a different bulb. Instead of a standard bulb that has a filament, the HID bulb has gases (Xenon) and salts. They have a little more that just a power and ground to run them. They need a higher power to turn the gases and salts into light. This is where a starter and a ballast come in. The car is connected to the starter which sends the signal to the ballast which is like a Amp for the lights. HID bulbs need time to warm up which is turning the gases and salts to light. That's why if you've ever seen them cut on the look like they flash on and then get brighter. So if you want better lighting and you want HID's you will need to get newer housings that acomidate the use of replacement bulbs and buy a HID kit that includes the Bulbs, Ballast and Starters. They normally come in a kit. All you need to do is hook up the power and ground to the starter, plug the HID bulb into the headlight and secure the placement of the ballast. Another thing to note is that HID's aren't recommended for high beams. Reason being is becuase people flash their high beams on and off. This is what actually causes the HID's to go bad. The starting of the gases and salts turning to light and then back off will cause the salts to not work properly later on. So since the low beams are on more at a soild time, that's why they are used. Now there are projector's that will allow the use of a signal HID bulb and has a flapper inside for the High beam so it actually is on all the time and won't ruin the bulb. That's another story though. Hope I gave you some more info. If you have any questions or I was confusing I'll certainly help.
05 Chevy 3500 Crew Cab Dually ![]() Sold ![]() |
