Old 01-15-2010, 03:57 PM   #1
BIGBLU 72
BIGBLU 72's Avatar
700r4 question
Im looking into buying a 700r4 out of a 92 S10 with 133000 miles on it. will this need to be beefed up to run behind my 400 small blocl (350+hp/400+ftlbs) and is there going to be any issues with linkage, lenght, or speedo hook up?
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 01-15-2010, 04:30 PM   #2
cdowns
cdowns's Avatar
Re: 700r4 question
yes to all your questions
Old 01-15-2010, 04:33 PM   #3
425HP409
425hp409
425HP409's Avatar
Re: 700r4 question
There is no difference in the V8 or V6 transmissions as far as strength is concerned. I would highly recommend having it rebuilt with the 9 clutch 3-4 clutch pack, Kevlar Band and larger boost valve. I would also replace the sun shell with the newer hardened one. You will have to get a front drive shaft yoke to fit it the transmission, (TH350 and TH700 are the same), shorten the drive shaft approximately 2.5 inches if you are still using a TH400, install a Throttle Valve cable to the carburetor, install a throttle valve bracket on the intake or carburetor, relocate your cooler lines to fit the trans, and move the frame cross member to the rear for the mount. If it is a 92 with a mechanical speedometer, you can use your existing speedometer cable but the speedometer gears will have to be calibrated to your specific differential ratio.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 01-15-2010, 04:52 PM   #4
BIGBLU 72
BIGBLU 72's Avatar
Re: 700r4 question
Ok so how much coin am I looking to shell out on this thing?
Old 01-15-2010, 05:54 PM   #5
425HP409
425hp409
425HP409's Avatar
Re: 700r4 question
You are going to spend from $1000-1800 on parts and trans rebuild and 600-1000 on labor unless you do it yourself.
Charles
90 ZR1 Corvette
