01-15-2010, 12:13 AM | #1 |
12 Bolt Carrier ID
Just trying to ID this carrier
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
01-15-2010, 01:41 AM | #2 |
60-66 Nut
Re: 12 Bolt Carrier ID
Well for starters, what are the numbers on the ring gear? There should be a part number, a date, and the tooth count of the ring and pinion. This will be a start in figuring out just what it is.
01-15-2010, 03:55 PM | #3 |
the differential is a eaton positive locking manufactured for general motors for the truck 12 bolt
unless the gears are changed they were 3.73 41 -11 or its a miss marked dana posi trac but I think its an eaton
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) Last edited by 62gmc910; 01-15-2010 at 03:59 PM. Reason: forgot stuff |
01-15-2010, 04:01 PM | #4 |
Rods
If you dont want it...send it to me
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
01-15-2010, 07:38 PM | #5 |
I figured it was a four series carrier, wasn't sure if it was an Eaton.
