Old 01-18-2010, 10:20 AM   #1
m6z
m6z's Avatar
3/4 ton to 1/2 ton differences.
I've got a few questions for you guys. Are the frames different between the 67-72 1/2 ton & 67-72 3/4 ton? Or is is just in the suspension?
Any issues bolting a dropmember onto a 3/4 ton frame?
Btw I searched and couldn't come up with anything. So if I missed it. My bad.
Thanks for the help,
Doug
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 01-18-2010, 11:25 AM   #2
crakarjax
crakarjax's Avatar
Re: 3/4 ton to 1/2 ton differences.
The 3/4 frames are taller. I am going to swap a 1/2 suspension on my 3/4 frame and I think everything will bolt on, or at least that's what I have read. The 3/4 trailing arms are beefier.
BTW what is a dropmember?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 01-18-2010, 11:41 AM   #3
m6z
m6z's Avatar
Ok, I was thinking I had read that the frames were taller. Just couldn't seem to find it. A dropmember is dropped front crossmember for air ride.
Can someone else chime in and confirm that the frames are indeed taller. I also just read in another thread stating that the c10 & c20 crossmembers were a direct swap. Any truth to that?
Doug
Old 01-18-2010, 04:14 PM   #4
m6z
m6z's Avatar
Nate from porterbuilt confirmed that the 3/4 ton chassis on the 60-72 trucks are the same as the 1/2 ton.
Doug
