Old 01-19-2010, 12:07 PM   #1
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Always use protection! CPP'S simple upgrade to eliminate shock stud failure,
Very good idea. Do you take pay pal?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 01-19-2010, 02:48 PM   #2
CPPJEFF
Yes we sure do. Thanks
CPPJEFF is offline   Reply With Quote
Old 01-19-2010, 08:37 PM   #3
damnyankee36
damnyankee36's Avatar
I've seen these before. Why do the stock mounts holes tend to fail on lowered trucks?
damnyankee36 is offline   Reply With Quote
Old 01-19-2010, 09:25 PM   #4
DKN
Active Member
The factory located the chock in such a way that that as the suspension is compressed (lowered) the shock becomes angled relative to the mounting stud. This angle results in a bending moment on the upper shock stud. Most lowered length shocks are valved stiffer than the OE length to compensate for the shorter suspension travel available because of the lowered ride height.
These brackets are very similar to the OE brackets used on some of the 4 wheel drive trucks. I guess GM figured out the stud was not attached very well but only fixed the problem on 4x4’s.
Danny Nix
CPP
DKN is offline   Reply With Quote
Old 01-19-2010, 10:35 PM   #5
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
I need replacements for my 4x4. Do your bolt holes line up with the frames OE rivet holes?
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 01-19-2010, 11:15 PM   #6
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I need a set or maybe even two..
Time to make the call.. and Thanks a bunch!!
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 01-20-2010, 01:33 PM   #7
DKN
Active Member
I made this part several years ago. I think it will interchange to the OE part. If it does not line up it is atleast very close and may end up working anyway.
Danny Nix
CPP
