Closed Thread
Old 01-19-2010, 08:03 PM   #701
lakeroadster
Re: What did you do to your truck today?
Made a 3 gauge panel to replace the heater controls in the Camaro dash. I like to call it the rare "Heater Delete" option. Then shot a coat of rattle can primer on the dash and gauge panel just to lighten it up a bit. It needs soem filler but I plan to run the dash like this through the year and tear everything back down next winter for bondo and paint.
Also spent some time organizing all the under dash wiring with wire ties in preparation for hooking up gauges. It might look nightmarish but now I know what every wire is thanks to my trusty 1965 Shop Manual.
lakeroadster is offline
Old 01-19-2010, 09:21 PM   #702
LILRED66
LILRED66's Avatar
Originally Posted by 198plus View Post
Looks great Tony...........Is that the grill I sold you ????
I think so Ronnie. I have a few of these going right now and I can't remember for sure, but I did use the nicest one I had and I believe that was it. Thanks.
LILRED66 is offline
Old 01-19-2010, 09:35 PM   #703
LILRED66
LILRED66's Avatar
Originally Posted by blackmopar View Post
Another great piece of info to have - thanks LilRed!
Some of the books and manuals I have are quite informative and not readily available, so they offer a lot of great details about these trucks.
LILRED66 is offline
Old 01-19-2010, 09:37 PM   #704
LILRED66
LILRED66's Avatar
Originally Posted by markeb01 View Post
Man that white ring/black background makes all the difference. Really beautiful.
Thanks mareb01. I appreciate it.
LILRED66 is offline
Old 01-19-2010, 11:31 PM   #705
DWright
Shlong Bed Club
DWright's Avatar
Replaced a heater core in a customers Chevy Equinox. Job calls for 10hrs and the car only had 60k on the odo. I know it doesnt pertain to our trucks, but i thought you guys might be interested.
I did however get my front suspension out from under my truck tonight.
cant seem to be able to post the pics. i'll try again later
DWright is offline
Old 01-19-2010, 11:40 PM   #706
markeb01
Senior Enthusiast
markeb01's Avatar
That's why I drive a 50 year old truck, the heater along with most everything else can be fixed or changed in minutes instead of days.
markeb01 is offline
Old 01-20-2010, 02:34 AM   #707
stretch-t
stretch-t's Avatar
Spent 3 hours grinding and sanding rust/dirt off the the rear 1/3 of the frame. Tomorrow plan is to finish the rust removal with a wire brush , then paint it with POR-15.
stretch-t is offline
Old 01-20-2010, 03:32 AM   #708
SCOTI
SCOTI's Avatar
I worked on modifying my rear shock c.member....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now
Old 01-20-2010, 09:20 AM   #709
4dranch
Shloooooong bed member #2
4dranch's Avatar
Started on some panel replacements..
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline
Old 01-20-2010, 11:20 AM   #710
Vernski
Originally Posted by LILRED66 View Post
Per the Chevrolet Truck Encyclopedia, all the '60-'66 Chevy trucks were done this way, including the single-tone and two-truck paint schemes. There may be some exceptions, but that is the way they were originally done.
Two obvious tale-tell signs of a repaint, are this area not having the black backdrop with the off-white accent ring or the firewall being any color besides the body color.
Hey Tony I was wondering does GMC do the same with there grills or is this a Chevy only thing? Thanks ---Vernski
Vernski is offline
Old 01-20-2010, 12:09 PM   #711
jbgroby
jbgroby's Avatar
On the GMC trucks. only the back area (behind the barbell) was blacked out, no trim color was done.
Jake
jbgroby is offline
Old 01-20-2010, 03:26 PM   #712
LILRED66
LILRED66's Avatar
I am not sure Vernski, but the GMC guys have the answer. I do believe it was only on the Chevy trucks, as noted above, by jbgroby.
LILRED66 is offline
Old 01-20-2010, 04:07 PM   #713
Vernski
Thanks guys for the answer on the GMC grills. Hey today I bought a 63 Chev swb knee knocker from a guy that was hurtin for sure. $500 and the title was mine. It needs bed wood and I will have to replace the rockers maybe just the drivers side. I'm a GMC guy but I wasn't passin' this up bbw an all. It has an I6 in it and it runs good. I'll start on it when I get my GMC done, it needs paint and some body work.---Vernski
Vernski is offline
Old 01-20-2010, 04:28 PM   #714
LILRED66
LILRED66's Avatar
Congrats Vernski...I don't know if I jealous or envious or both. Keep us posted and nice score.
LILRED66 is offline
Old 01-20-2010, 05:00 PM   #715
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Good score, looks pretty straight..
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline
Old 01-20-2010, 11:55 PM   #716
sams60gmc
sams60gmc's Avatar
I did some work yesterday and today on my rear backhalf. I made my top tri link tabs and today I squared up my frame and rearend, set the pinion angle and built the top links. I ran into a small problem with where my links were headed so I had to bend them so they would hit the middle adjustment. But I'm glad I did because it turned out sweet. I had to pie cut it because I don't have a tube bender and didn't want to wait. My bungs are tacked in and its tacked in the front and the tabs are tacked aswell. Anyways here are some pics and I did a walk around and video'd it and I'll have that up later.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 01-21-2010, 12:09 AM   #717
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i did some measuring for a y pipe then set it back on the ground and tried a little (with open headers)
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline
Old 01-21-2010, 12:34 AM   #718
70 Suburban
Rods
bench tested the dash and a/c from the 08 chevy. it works so ill be tryin to figure out how to get it in the 66
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline
Old 01-21-2010, 12:43 AM   #719
ruffrida2005
Sam60 Do you know what your ride height is going to be set at on your truck?
Paul
Old 01-21-2010, 01:24 AM   #720
sams60gmc
sams60gmc's Avatar
Should be about the same as or around about a 5'' drop on a shortbed.
Old 01-21-2010, 01:42 AM   #721
sams60gmc
sams60gmc's Avatar
Old 01-21-2010, 11:13 AM   #722
protrash64
Resistance is Futile
protrash64's Avatar
Nice work sams60 .......also congrats on one of the most popular and long running threads I've seen.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline
Old 01-21-2010, 12:33 PM   #723
Martin64
Martin64's Avatar
I parked mine in the neighbor's carport to keep tree limbs/trees from falling on it while it's windy....they park in the street since there's no tall trees in front of the building.
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline
Old 01-21-2010, 12:49 PM   #724
sams60gmc
sams60gmc's Avatar
Thanks!!
Old 01-21-2010, 01:00 PM   #725
markeb01
Senior Enthusiast
markeb01's Avatar
With unseasonal temps in the high 40's and low 50's, I got mine out of storage and back in the garage for new trailing arm bushings, a relay for the heater and maybe more upholstery.
markeb01 is offline
Closed Thread
