Old 01-17-2010, 11:49 PM   #26
protrash64
Resistance is Futile
protrash64's Avatar
Re: Project: Recycle
Nice work SCOTI!!!! Looking good......
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-17-2010, 11:49 PM   #27
VA72C10
VA72C10
VA72C10's Avatar
I like how you matched up the notches....it's that attention to detail that takes a build up from nice to SWEET
Old 01-17-2010, 11:56 PM   #28
SCOTI
SCOTI's Avatar
Once the rear c-notches were done, I started installing the rear truck arms from Nathan @ Porterbuilt.
I initially intended & mocked the rear up for OE arms & shop built 2" lowering blocks. But, I was able to give input to Nate on building these arms & got a shot @ some of the first sets built w/specific tweaks that I believe are now standard production. I had to wait a few extra weeks (it was longer than 2 ), but they are worth it to ensure everything can move w/o binding.
I then moved on to the Panhard bar. I wanted true adjustability both centering the rear housing to the frame & setting the bar level @ ride height. I tried both the 65 & 68 OE style frame brackets but just couldn't get the bar level so I started building my own.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 01-18-2010, 12:04 AM   #29
SCOTI
SCOTI's Avatar
So, here's the info on the Panhard bar bracket. I figure it's already here on the board so I won't re-post....
http://67-72chevytrucks.com/vboard/s...d.php?t=368476
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-18-2010, 12:26 AM   #30
SCOTI
SCOTI's Avatar
That's about where I'm @ on the chassis for now. I've been working on the rear gas tank location (height & for/aft location), upper shock brackets, & clearancing for exhaust to make it all the way to the rear bumper.
I have the PHB triangulating c.member notched, the upper shock mounts fabbed/tacked in place, & c-notched the shock c.member. I'll get some pics of that this week as I ran out of time between work & helping some friends move this weekend. I'm waiting on the actual shocks too....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-18-2010, 09:57 AM   #31
Jonboy
Slots go on anything!
I can't wait to see this thing in person. Subscribed!
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 01-18-2010, 02:38 PM   #32
greg65
greg65's Avatar
Good looking frame, can't wait to see it finished.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 01-19-2010, 09:59 AM   #33
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Subscribed... awesome write-up so far SCOTI!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-20-2010, 02:41 AM   #34
SCOTI
SCOTI's Avatar
Alrighty.... I got most of the shock c.member welded up & ground down (good enough for pics anyway ). I plan to add some gussets between the lip of the c.member & each side of the upper shock plates but I didn't have them 100% ready for welding in yet....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-20-2010, 03:02 AM   #35
SCOTI
SCOTI's Avatar
I'm using Porterbuilts Dropped Truck Arms on this truck.
The shock mounts w/the PB truck arms accomodate a standard GM shock stud. I measured off of the C/L of the lower stud to calculate some rough numbers for shock length/travel. I needed a rear shock that was approx 17" @ ride height.
I tried some G-body shocks I had stashed away (I have a Malibu too) & realized the shocks were pretty close to ideal if mounted flush w/the top of the OE truck shock c.member. The drawback was the upper mounting configuration was different.
The different/fabricated upper shock plate for the c.member allows me to use the A/G body rear shocks (they measure 21" extended; 13" compressed) & put the shock length about dead middle of its range @ my anticipated ride height.
My truck has just over 3" of compression before bottoming out on the c-notches so that will prevent the shocks from bottoming out & I've calculated max extension @ no more than 3" as well so these should work very well. The mounted shock angle is approx 57°....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-20-2010, 03:13 AM   #36
SCOTI
SCOTI's Avatar
The notched portion of the c.member was necessary because I wanted exhaust all the way to the rear bumper (I dis-like how turn downs stir up dust/dirt).
Since my bed floor will be raised 3" above the frame rails, the notches allow for routing of exhaust over the c.member (going under gets it too close to the rear axle) w/plenty of clearance (no rattles). This routing choice also required notching the Panhard bar triangulation c.member so that the exhaust can drop back down before the gas tank (69-72 Blazer tank).
As you can see, this mod allowed almost 4.25" between the c.member & bed-floor & just over 4.5" between the PHB c.member & gas tank lip. Some 2.5" pipe should route through there w/no problems.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-20-2010, 08:25 AM   #37
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking great bro...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-20-2010, 08:55 AM   #38
lolife99
67-72 parts collector,…
lolife99's Avatar
Excellent detail.
You have way more patients for taking pics and documenting everything, than I do.
(on a side note,... how about one picture of your Malibu?)
Old 01-20-2010, 09:36 AM   #39
MattA
MattA's Avatar
That crossmember looks great.
Here is the Malibu project
MattA is offline   Reply With Quote
Old 01-20-2010, 09:58 AM   #40
SCOTI
SCOTI's Avatar
Originally Posted by matta View Post
that crossmember looks great.
Thanks!
Old 01-20-2010, 10:00 AM   #41
SCOTI
SCOTI's Avatar
Excellent detail.
I try & remember to take pics as I go.
Alot of these were @ the end of the work just for the glamour shot. I installed/removed those c.members a bunch of times measuring & making sure things were going to work like I wanted.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-20-2010, 10:23 AM   #42
Jonboy
I dig the Malibu, too. I need a wagon like that.
Old 01-20-2010, 11:25 AM   #43
VA72C10
VA72C10
VA72C10's Avatar
nice work and attention to detail!
Old 01-20-2010, 12:24 PM   #44
lolife99
lolife99's Avatar
Sweet Malibu!
I use to have a '78 as my daily driver.
Old 01-20-2010, 04:19 PM   #45
MattA
MattA's Avatar
Sweet Malibu!
That car has been in our "family" for about 15 yrs. ScotI's brother had it, I bought it from him and drove it for about 6yrs. My son drove it for a few years and locked the motor up. I took it apart and started to mini-tub/ frame rail notch the rear. I ran into some financial difficulties and Scot bought it from me about 3 yrs ago.
It will get finished by someone eventually.
Old 01-20-2010, 07:48 PM   #46
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
awesome build
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 01-20-2010, 07:53 PM   #47
SCOTI
SCOTI's Avatar
Of the multiple 78-81 Malibu's I've owned (3 2drs & 2 Camino's), this one is the cleanest as far as floor-pan rust issues. I still accumulate parts for it when I see something it will eventually need....
Originally Posted by jgh64pkup
awesome build
Thanks!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-21-2010, 09:07 PM   #48
LEEVON
LEEVON's Avatar
SCOTI, did you cut that bed down or just using that frame?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-22-2010, 01:50 AM   #49
SCOTI
SCOTI's Avatar
The frame was a 68 lwb that I shortened & cut up for the 64 swb body. I've learned over the years of 'not yet completed' projects to not take anything apart until I'm 100% ready to immediately put it back together (some guys can; I can't). Building the replacement rolling chassis also allows me to get some cool photos of the naked drivetrain & chassis (to show off the work that the 45yr old body will be covering up).
If you're asking specifically about the bed floor, it was part of a package deal from an old board member here in Dallas. I bought the entire short fleet bed @ a good price but only wanted the tailgate & steel floor. I re-sold the fleet tubs to FirstGen; the bedsides, front panel, & tailgate to n2billet, & kept the floor for free .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-22-2010, 10:53 AM   #50
LEEVON
LEEVON's Avatar
Ahhh, now I understand. I'm the same way about getting everything ready and not stretching it out. I've been looking at bare chassis to build and worry about the truck later.
This thing is gonna be sweet!
