Old 01-20-2010, 05:12 PM   #1
cedorris
1972 Chevy Cheyenne Super
cedorris's Avatar
Complete Rubber Kits
I'm in the middle of a restore and want to replace every piece of rubber. Does anyone sell a complete rubber kit so I don't have to buy every piece one by one?
-Clayton
1972 Cheyenne Super LWB 350 - farm truck restore project - twitter @oldgreen
cedorris is offline   Reply With Quote
Old 01-20-2010, 05:26 PM   #2
70cst
70cst's Avatar
Re: Complete Rubber Kits
If you go the the Vendor area you will find help...
Classic Heartbeat and Christian Classics I am sure can put together a full set for you. Just give them a call and I am sure they can help you out.
WES at...
http://www.classicheartbeat.com/
Tim at...
http://www.christiansclassics.com/
There are other great suppliers you can choose from if you go the the Vendor area... Good Luck.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-21-2010, 07:46 AM   #3
GMCPaul
We carry a complete cab rubber seal kit, it includes the following
Kit includes your choice in the following
1- Windshield seal in your choice of ( Standard or 67-70 Deluxe or 71-72 Deluxe )
1- Rear Window Seal in your choice of
( 67 Small Standard, 67-72 Large Standard or 67-72 Deluxe for use with trim )
1pr- Door Opening Weatherstrip
( Mitered Corners 100% Correct Does both doors)
1- 4piece Vent window Seal Set
( Does both doors )
2- Division Bar Felts ( Does both doors )
2- Glass Run Channels ( Does both doors )
1- Door Glass Anti-Rattle Set including the following pieces
2- Inner Window Felts ( Does both doors )
in your choice of Standard or Chrome Bead
2- Outer Lower Window Rubber Scrappers ( Does both doors )
Specify in cart options desired in comments section on windshield, rear window seals and anti-rattle set with or without chrome bead. All seals in kit are backed with a manufacturers lifetime warranty. Manufactured by Precision, this kit is a certified GM restoration part.. Ships Fed-Ex ground Oversized.
Part# 1191622
You'll find it on sale currently on the following pagfe of our web site for $160.00
http://www.gmcpauls.com/SALE_SPECIALS.htm
GMCPaul
GMCPaul is offline   Reply With Quote
Old 01-21-2010, 08:29 AM   #4
70cst
70cst's Avatar
There yo go cedorris....GMCPaul is another good source for our trucks. You will find Paul very price competitive, he knows our trucks and he is a straight shooter.
Old 01-21-2010, 08:33 AM   #5
Sammy
Manufactured by Precision. Best quality that I know of also!
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 01-21-2010, 05:00 PM   #6
cedorris
cedorris's Avatar
Thanks, GMCPaul.
I've got a question... What are the flat rubber pieces that go between the cab and the front of the doors on the 72? They look like some kind of noise reducing pieces.
-Clayton
Old 01-22-2010, 06:47 AM   #7
GMCPaul
The rubber pieces you are asking about are called the front fender dust shields. The metal bracket they are attached to are not reproduced so you need to save them. The rubber flaps and large brass staples to hold them in place on the metal strip are available. To install them you have to bend the folded ends of the original staples till they are straight and pull them out. After these are removed you can lift the old rubber dust shields off then you place the new dust shield on the original metal bracket and place the staples through the openings and then bend the end over to hold it in place.
You'll find these on the following page of our web site
http://www.gmcpauls.com/rubber&ws1.htm
The last item on the page Part # 998215
Have a great weekend!!!!
GMCPaul
Old 01-22-2010, 11:26 AM   #8
cedorris
cedorris's Avatar
Thanks again GMCPaul.
You can be expecting some orders from me in the near future!
-Clayton
Old 01-25-2010, 11:43 AM   #9
cedorris
cedorris's Avatar
Alright GMCPaul, I have one last favor to ask...
Can you put together a shopping list of sorts for every piece of rubber I need on a 72 Super Cheyenne, LWB, 2WD, Auto. I want to replace everything except maybe the grommets in the firewall.
Your prices are way better than my local guy.
The first thing I need is cab mount bushings.
Thanks!!
-Clayton
